Steering Wheel Squeek with Video - Honda Pilot - Honda Pilot Forums
Old 10-07-2011, 08:14 PM   #1 (permalink)
Default Steering Wheel Squeek with Video
Can anyone confirm or deny this is the steering wheel cable I'm hearing?
Thanks.
fasterisbetter is offline   Reply With Quote
Old 10-07-2011, 08:20 PM   #2 (permalink)
OMG! I have the same exact squeak and I've been trying to figure out what is causing it.
I second the OP's question.
Does anyone know what is causing it and how to fix it?
megatron is offline   Reply With Quote
Old 10-08-2011, 01:39 AM   #3 (permalink)
theirishscion's Avatar
Certainly sounds like the clockspring casing. If it were something rubbing on the steering shaft itself, I don't imagine it would have the high frequency plastic-y sound.
However, no way for me to confirm it having not experienced the same thing myself.
If you're confident doing your own work, disconnect the battery (to disable the airbag) and pull the steering wheel off. That should expose the clockspring (possibly after removing some upper and lower steering column cowling)
Make sure you very carefully mark wheel orientation before you remove it, otherwise it's liable to be slightly turned to one side as you drive straight down the road, which is annoying.
"The HDMI Wagon"
Old 10-14-2011, 04:19 PM   #4 (permalink)
I asked my mechanic to give the video a listen and he referred me to a TSB (mentioned here too - TSB 09-068: Squealing Noise From the Steering Column While Turning the Steering Wheel) and said the problem was the switch.
I'll be getting it fixed in the next month and will report back if this is indeed the issue. He said $145 for parts and labor.
2006 Honda Pilot EXL
Old 10-14-2011, 05:15 PM   #5 (permalink)
Is this a Honda Dealer price? Or 3rd party? That sounds pretty good considering labor rates alone now are at approx $100/hr.
Can you or someone give me the Honda part number of the part that needs to be replaced??? I tried going to that TSB, but the link doesn't work anymore. Does anyone have a PDF copy of it somewhere that I can go to?
Thanks!
Old 10-14-2011, 05:21 PM   #6 (permalink)
3rd party price. Shop uses OEM parts but they're definitely better priced than the dealership.
I'll try to get more info on the TSB when I take it in if no one else has posted it by then.
Old 11-17-2011, 10:28 PM   #7 (permalink)
I didn't get any more information but the $145 fixed the problem.
