2003 Pilot Shifter Loose - Honda Pilot - Honda Pilot Forums
Old 09-29-2011, 02:55 PM   #1 (permalink)
Unhappy 2003 Pilot Shifter Loose
Seemingly out of the blue the shifter on my 2003 Honda Pilot (103,000 miles) started acting up. It's not shifting into the gears solidly and at times it takes a minute to line it up into the proper gear. It's not flashing like I saw alot of people have problems with. I brought it to the dealer and they said I had a stretched detent spring. When they repalced it they said the bracket holding the spring was broke. Replacing that had no effect. On the 4th visit they said that the problem is a module in the transmission and that I need a new one. Wow, it runs fine once its in gear. Any ideas?
rickok is offline   Reply With Quote
Old 09-29-2011, 03:35 PM   #2 (permalink)
Underdog's Avatar
I have a similar problem with my 04. Taking it to my mechanic tomorrow. I'll advise.
IMO .......if the dealers where you live are anything like the dealers here, Stay far far away. They seem to only hire incompetents and are as crooked as a "dog"s hind leg" . They'll screw you out of hundreds of dollars to repair (They're in reality nothing but R & R artists) what a "Real Mechanic" can fix for a fraction of the cost.
Underdog is offline   Reply With Quote
Old 09-29-2011, 04:36 PM   #3 (permalink)
Hard to shift
While the symptoms are different, I'm willing to wager that the cable connecting the shifter to the gearbox is loose/stretched/out of adjustment. There have been a couple of people with older Pilots in the rustbelt/snow states with shifter cable issues.
Old 10-01-2011, 07:33 AM   #4 (permalink)
Underdog's Avatar
Mechanic advised that the Shifter Cable is binding. He attempted to lube it. It really didn't help that much. He recommends that the cable be replaced.
Old 10-01-2011, 08:43 AM   #5 (permalink)
That was Mainer's experience too.
Old 10-06-2011, 07:35 AM   #6 (permalink)
Underdog's Avatar
Cable replaced and the issue is resolved. Shifter is like new again.
Cable $200, Labour $75 so with taxes $310.00.
Old 03-28-2012, 01:16 PM   #7 (permalink)
Garage
Default Same issue
I am having the same issue with my 2003 Pilot as described in the first forum. So, I will take the advice - thanks!
greenwoodpipi is offline   Reply With Quote
Old 03-28-2012, 03:16 PM   #8 (permalink)
94eg!'s Avatar
For future reference: Cable for a 2004 can be purchased for $116 straight from online Honda dealers
Part Detail
