auto windows 04 EX - Honda Pilot - Honda Pilot Forums
Old 09-26-2011, 08:12 AM   #1 (permalink)
Default auto windows 04 EX
My drivers side window no longer goes up or down automatically when quickly pressing the button.
At first I thought it was a fuse or something and then I started digging thru some threads and found it may be a weak battery issue and the auto feature needs to be re-learned.
How could the battery be the cause of the problem, and why does the auto feature need to be re-learned?
None of this makes sense to me.
njitgrad is offline   Reply With Quote
Old 09-26-2011, 08:42 AM   #2 (permalink)
When power us lost it forgets. Instructions on how to teach it again are in the owners manual.
Old 09-26-2011, 10:15 AM   #3 (permalink)
Whether it makes sense to you or not is irrelevant, that's what happens to the auto down/up feature with a weak or dead battery.
Old 09-26-2011, 01:26 PM   #4 (permalink)
I just followed the directions in the manual. After holding the window in the UP position for 2 seconds I heard/felt a little movement behind the door (mechanism resetting?). For the next 5 seconds or so I could not move my window up or down. Eventually it did respond, however the AUTO feature is still not working.
What next?
Old 09-26-2011, 07:59 PM   #5 (permalink)
There shouldn't have been any sort of movement when you did the procedure. Did you try to reprogram it again?
Old 09-28-2011, 02:20 PM   #6 (permalink)
I repeated the process three times yesterday with no success. However this morning my auto window feature miraculously worked. Gremlins?!?!?!!
