Brake Light switch needs replacement?
Honda Pilot 2008. Started it but could not get out of park. Noticed that turn signals, hazard lights, and horn also stopped working. Used the shift lock release to get it into neutral and was able to get home. Noticed that brake lights are not working but they do come on when locking the doors. Found that fuses were blown for horn and hazards. I have read that it could be the "brake light switch" controlled by the brake pedal. If this went bad, could it be the reason the fuses blew for the horn, hazards and turn signals? I don't see a specific fuse for the brake lights......Do you think I just need to replace the "brake light switch" or may there be another problem???
