AC Blower Motor Issue - Honda Pilot - Honda Pilot Forums
Old 09-01-2011, 11:00 PM   #1 (permalink)
Default AC Blower Motor Issue
Hi all,
I'm new to the forum. I have a 2008 Pilot with the electronic climate control. Within the last day or so there has been no air blowing out of the front vents. There is ice cold air coming from the rear unit and the fan speed changes based on the temp setting in auto mode as well as by the manual buttons. The AC compressor is cycling on and off properly and is making cold air which is only coming out of the rear vents. I couldnt find any fuses for just the front blower. I have checked all the manual settings on the climate control and can't get anything to come out of the front vents.
I have searched some of the other similar threads but my issue seems a little different than others.
Any help would be greatly appreciated. The base warrantee has expired.
CM
NJ08Pilot is offline   Reply With Quote
Old 09-02-2011, 08:54 PM   #2 (permalink)
I find electrical issues the worst. I don't have your year Pilot, mine is an 03. From my 03 service manual:
There is a blower relay that you should check, and I have two fuses, #55 for the rear blower (30 amp) and #56 for the front blower (40 amp), both under the hood. I can't tell if the relay services both blowers or not.
Next I would see if there are any diagnostic trouble codes (DTC's) that would point you in the right direction.
After checking those my next step would be to pull the blower motor out and check that power is being delivered with a volt meter, if so I would check the motor.
Good Luck
SD16 is offline   Reply With Quote
Old 09-12-2011, 01:28 PM   #3 (permalink)
I believe you need to replace part #80560-S0X-A01 called a thermistor it lists for 133.00 . That is what caused mine to stop blowing and once replaced it worked like a charm. I did it my self and it is behind the glove box. rp the cabin filter while you are there.
halljk is offline   Reply With Quote
Old 11-10-2011, 09:06 PM   #4 (permalink)
Will you please post a pic of the part?
Does anyone know if it can be repaired with a $2 thermal fuse as can be done on the power transistor for the rear blower?
Here's the post on that fix:
Rear blower Transistor Fix
2004 Honda Pilot EX - 158,000 miles
isrb710 is offline   Reply With Quote
Old 11-11-2011, 05:10 PM   #5 (permalink)
jpd0363's Avatar
Don't know if NJ08Pilot resolved his problem, but the attached link might be helpful.
No Air / Center Front Vents & Rear Vents
The difficult done immediately, the impossible takes a little longer, Miracles by appointment. Wars fought, bars emptied, tigers tamed, virgins converted, chastity belts unlocked. Sportsman specializing in tasting of sundry alcoholic beverages. Defender of orphans. All-around good guy.
Almost forgot, Pilot owner!
jpd0363 is offline   Reply With Quote
