2003 blower motor intermittent - Honda Pilot - Honda Pilot Forums
Old 07-27-2011, 06:35 PM   #1 (permalink)
Default 2003 blower motor intermittent
A few days ago I ran over something at 65MPH that kjocked my allignent way out of wack.
I got that fixed but ever since the front ac blower motor has gone on and off when going over a bump or street wave.
When off recirc light off even though control panel still works and rear blower working but not cool.
RED ROCK PEARL
WEBASTO 749 SUNROOF, GARMIN 2610 GPS, FOG LIGHTS, PS/AT COOLERS, HITCH, FULL SIZE SPARE, SIDE STEPS, CROSS BARS, ALL WEATHER MATS, CARGO MAT, PERFECT FIT WIND DEFLECTOR, MB QUARTZ SPEAKERS, KICKER 5 CHANNEL AMP AND SUB, PIE AUDIO IN ADAPTOR, REAR SPLASH GUARDS, 3M FOG LIGHT PROTECTION, 3M DOOR GUARDS, 3M B-PILLAR PROTECTION, CENTER CONSOLE PADS, WHEEL LOCKS, 2004 HORN UPGRADE, THULE MOUNTAINEER CARGO BOX, MICHELIN CROSS TERRAINS, XM Commander with PIE input adaptor and Metra Power harness, LED interior lighting,DVD portable with Suspension theatre, Muth Signal mirrors with heated option, Helios HID hi-lo conversion kit, rear subframe brace retrofit
HDTVEE is offline   Reply With Quote
Old 07-27-2011, 07:01 PM   #2 (permalink)
IF the front AC is no longer cooling, you might have damaged the condenser.
Sounds like the fan switch is overheating, cutting out, cooling and coming back on again.
If accurate, the solution is to replace the switch.
