Left courtesy map light doesn't always come on - Honda Pilot - Honda Pilot Forums
Old 07-15-2011, 06:09 PM   #1 (permalink)
Default Resolution: Left courtesy map light doesn't always come on
Just recently the left map light courtesy doesn't always come on when you open the doors. I tried replacing the bulb but the issue still occurs.
I bought the extended warranty so hopefully it is covered should the whole unit need to be replaced.
Any other ideas are appreciated.
tomas21 is offline   Reply With Quote
Old 07-16-2011, 10:55 AM   #2 (permalink)
Searched all night and came across this post
Will update after I do some tests today.
Old 07-16-2011, 10:38 PM   #3 (permalink)
No luck. Going to take it into the dealer to cover electrical under warranty
Old 07-19-2011, 10:03 AM   #4 (permalink)
Went to the dealer yesterday and they said that the contacts in the back of the left base had a short of some sort. This is supposedly a common issue on Pilots and Accords.
Fix: They replaced the base 34999 with part no: 34404-SDA-A21 covered by my extended warranty.
Old 07-19-2011, 06:01 PM   #5 (permalink)
samc's Avatar
So the dealer repair is just to replace the whole unit? Samething is happening on my pilot and I was reluctant to take it to the stealership. I'll make an appointment one day.
And I found this. I'll try it this weekend.
http://www.ridgelineownersclub.com/f...t=22832&page=5
Again I would take it to the dealership but I hate waiting there for 3-4 hours (till the whole day sometimes) for minor repairs.
Old 07-19-2011, 06:30 PM   #6 (permalink)
Congrats on getting it fixed under warranty.
2005 LX 4wd
OEM accessory roof bars
OEM nerf bars
OEM rear splash guards
2006 OEM 4wd emblem
Garmin GPS
Aftermarket tinted windows
OEM accessory fog light kit
OEM accessory cargo cover
Silver painted grill
Acura stainless exhaust tips
KYB GR2 struts/shocks
Curt 13328 Hitch
Old 07-23-2011, 03:18 AM   #7 (permalink)
I need to replace a map light, how do I go about disassembling the map light unit?
avance is offline   Reply With Quote
Old 07-24-2011, 10:52 AM   #8 (permalink)
samc's Avatar
I believe it's like two screws under the sunglass holder and two more under each lense (the one you press to turn the lights on).
Old 08-01-2011, 10:27 PM   #9 (permalink)
J-Nay's Avatar
I had the same issue with my driver side map light. I ended up taking apart the unit. I pulled the switch off and checked it for continuity which was ok, so I cleaned off the leads on the base and put the switch back on and, viola, light worked! Maybe I was just lucky, but maybe other people just have a bad connection as well and this is about the cheapest fix you could ask for
2007 Pilot EX-L RES
Formal Black w/ Saddle INT
J-Nay is offline   Reply With Quote
