Transmssion over heated - Honda Pilot - Honda Pilot Forums
Old 07-06-2011, 11:38 PM   #1 (permalink)
Default Transmssion over heated
About a month ago my d4 started flashing and like many others i turned the car off and the light went away. Last week while driving up to the mountains my transmission started jerking like crazy and the rpm starting jumping up and down, i pulled over and heard the trans oil boiling. I sat for about an hr to let the oil cool and was able to turn around and drive back home with no problems. With the transmission over heating the way it did should i even bother trying to repair it or should i just get it rebuilt? I need some advise before making this every expensive decision.
kspilot is offline   Reply With Quote
Old 07-07-2011, 12:56 AM   #2 (permalink)
Need to pull codes and attempt to determine cause before deciding what to do. There are many electrical components that could have failed and caused the condition. Sometimes, a cheaper alternative can be found to repair the tranny and delay replacement. Also, check fluid level. Also, check radiator for signs of trans fluid leaking into it from the built in trans fluid cooler. If you do repair that trans (as opposed to replacement), be sure to replace that burnt fluid, too.
2005 LX 4wd
OEM accessory roof bars
OEM nerf bars
OEM rear splash guards
2006 OEM 4wd emblem
Garmin GPS
Aftermarket tinted windows
OEM accessory fog light kit
OEM accessory cargo cover
Silver painted grill
Acura stainless exhaust tips
KYB GR2 struts/shocks
Curt 13328 Hitch
Old 07-07-2011, 12:59 AM   #3 (permalink)
dustino8's Avatar
Curious, how did you hear the trans oil boil?
Another question, did the trans temp light illuminate?
2007 Toyota Tundra
Old 07-07-2011, 03:55 AM   #4 (permalink)
After turning off the car i could hear the oil boiling sitting inside the car it was pretty loud and the only lights that came on were the MIL and the D4
