New Battery, Changed Odometer! - Honda Pilot - Honda Pilot Forums
Old 07-02-2011, 11:49 PM   #1 (permalink)
Erniedog's Avatar
Send a message via ICQ to Erniedog Send a message via AIM to Erniedog Send a message via Yahoo to Erniedog
Default New Battery, Changed Odometer!
Hi All,
I went to Advanced Auto Parts and purchased a new battery which came with free installation using the memory keeper tool but when I got home I realized that the Odometer jumped up from 82,500 to 87,500. This I couldn't overlook because I just had 4 new tires installed on 6/30/2011 and the receipts also states the mileage at 82,500. The radio and clock are fine.
I have a 2005 Pilot EX-L.
I bought the car in 2007 and it had 32,000 miles. I also have had 255x55x18's since 08.
Any suggestions? I'm calling Honda and Advanced Auto on Tuesday.
Erniedog is offline   Reply With Quote
Old 07-03-2011, 12:23 AM   #2 (permalink)
Send a message via Yahoo to cali510
Have you tried to disconnect and install again?
cali510 is offline   Reply With Quote
Old 07-03-2011, 12:24 AM   #3 (permalink)
I've changed the battery twice in my 2005 and never had that problem.
Old 07-03-2011, 12:29 AM   #4 (permalink)
samc's Avatar
I've never heard of such a problem before in any make but I guess there is a first for everything?
Try honda, but I doubt advanced auto parts will do anything.
Old 07-03-2011, 09:12 AM   #5 (permalink)
Erniedog's Avatar
I've been searching online for an answer and what I've come across is 1) disconnect the negative post for 15 minutes then insert the ignition key before reconnect and 2) is to check to see if it's at KPH instead of MPH. The latter doesn't sound like the problem because I did the math and the mileage would have jumped to the 133k range.
A few web sites stated that it may have set the mileage reading of the vehicle using the larger tires which would added the additional 5% when the battery was changed. This adds up to the 87500 jump but I thought the computer calibrated the size difference automatically.
This is weird to say the least.
Old 07-03-2011, 09:14 AM   #6 (permalink)
Erniedog's Avatar
I'll post what happens after I try the disconnecting of the negative in about an hour.
Old 07-03-2011, 10:52 AM   #7 (permalink)
This doesn't sound possible. Are you sure the tire place didn't just copy the mileage down wrong when you got the tires changed? 82,500 sounds like too even a number to have been actual mileage. Also you said when you got home, it was 87,500. That too sounds like too even a number.
Something just doesn't sound right. I think human error is the factor here... not a technical issue with the odometer.
megatron is offline   Reply With Quote
Old 07-03-2011, 11:02 AM   #8 (permalink)
Erniedog's Avatar
Well I just tried the disconnecting of the positive terminal with the ignition on then reconnecting and nothing other than having to reset the clock and radio. (I had the code)
The possibility of human error did cross my mind but I am sure that I was at the 82/83k range and not so close to hitting 90k.
I just called Advanced Auto and as someone mentioned prior, their clueless. I'm going to call Honda on Tuesday.
There are multiple posts about a Class action lawsuit regarding Honda Pilot Odometer reading but I don't think they involve dramatic jumps just inaccuracies in MPH/KPH.
Old 07-03-2011, 11:02 AM   #9 (permalink)
RSQ Pilot's Avatar
Garage
Weird, how many miles was it from the tire shop to Advanced Auto to home? If it was 82500 at the tire shop then some odd number of miles should have rolled up on the odometer by the time you got home.
Old 07-03-2011, 11:07 AM   #10 (permalink)
Erniedog's Avatar
approx. 17 miles from Discount tire to my house.
Old 07-03-2011, 11:08 AM   #11 (permalink)
Erniedog's Avatar
Oh wait it is approx. 5 miles from AA to my house. I thought you were talkng about the tire shop.
Old 07-03-2011, 11:10 AM   #12 (permalink)
Erniedog's Avatar
Remember the mileage was 82500 on Thursday so I put about another 25 miles or so since by the time I actually got to Adv. Auto. So it wasn't an exact 5k jump but I was giving and general idea as to around 5k.
Old 07-03-2011, 11:12 AM   #13 (permalink)
RSQ Pilot's Avatar
Garage
So if it was 82500 when the tires were installed on 6/30, the mileage should have increased to 82517 or more assuming the tire shop was correct. A reading of 87500 after the battery install makes no sense at all.
Old 07-03-2011, 11:16 AM   #14 (permalink)
Erniedog's Avatar
I hear ya brother, I hear ya. This is weird. There is no way it should have jumped to that number. I'm stumped.
Old 07-03-2011, 11:31 AM   #15 (permalink)
Erniedog's Avatar
First of all I want to thank all of you Piloteers that responded. I appreciate you time and patience.
I sat down after my last post and thought how can I get a true reading of my odometer from a previous auto repair visit and I remembered that I had my oil changed at jiffy lube about 6 weeks ago. So I just called them and sure enough the odometer was at 86k+ miles.
Human error at the tire shop for sure and my poor memory.
That receipt from the tire shop really thru me off.
Thanks again.
