Rough idle - Honda Pilot - Honda Pilot Forums
Old 06-26-2011, 10:42 PM   #1 (permalink)
Default Rough idle
I have a 2003 Pilot with 107K mileage. On Thursday I had work done including replace timing belt, water pump, hydralic tensioner, "tune up" to replace spark plugs, transmission fluid, engine oil/filter. It ran fine until two days later when the malfunction indicator light came on and later the VTM-4 light. The idle turned rough and there was vibration (off and on) in the engine when accelerating. The engine vibration goes away when with letting off gas or canceling cruise control. The gas mileage was affected significantly. EGR valve replaced in 2007.
Could this engine vibration/rough idle be due to the recent work or a new problem (O2 sensor or other)? Thanks for any info.
jshannon is offline   Reply With Quote
Old 06-27-2011, 01:48 AM   #2 (permalink)
theirishscion's Avatar
Well, get the code read immediately for sure, but yes, given the proximity to the timing belt job, I'd say it's entirely possible that the timing belt skipped a tooth or three. I'd take it back to whoever did the timing belt and raise a stink, and I'd do it quick before it slips another tooth and starts bending valves. Of course, it might not be that at all, but better safe than sorry in this circumstance.
"The HDMI Wagon"
Old 06-27-2011, 09:21 AM   #3 (permalink)
I would also suspect a damaged engine mount. Especially since the vibration disappears when you lift off.
Old 06-27-2011, 10:43 AM   #4 (permalink)
Thanks for your suggestions. Going to Autozone for codes and will give updates.
Old 06-27-2011, 11:44 AM   #5 (permalink)
It is a P0300 code
Definition: random cylinder misfire detected
Probable cause: fuel system concern, ignition system concern, MAF sensor faulty, heated oxygen sensor/air-fuel ratio sensor fault, blocked intake or exhaust system
Old 06-27-2011, 04:32 PM   #6 (permalink)
I took it to the same place that did the original work. Within 30 mins they were finished and said it was a vacuum cover that had come off. It was put back on and the car seems fine.
Old 06-28-2011, 05:02 PM   #7 (permalink)
Problems that happen soon after work was done is usually caused by that work. Always take it back and have them check it out before assuming something new has broken.
2005 LX 4wd
OEM accessory roof bars
OEM nerf bars
OEM rear splash guards
2006 OEM 4wd emblem
Garmin GPS
Aftermarket tinted windows
OEM accessory fog light kit
OEM accessory cargo cover
Silver painted grill
Acura stainless exhaust tips
KYB GR2 struts/shocks
Curt 13328 Hitch
