2004 Pilot Oil Drain Plug Rounded Off!! - Honda Pilot - Honda Pilot Forums
Old 06-03-2011, 11:34 PM   #1 (permalink)
Default 2004 Pilot Oil Drain Plug Rounded Off!!
Help... While trying to unscrew the oil drain plug on my 04 Pilot, the plug rounded off. I've tried sockets and wrenches. There is almost no room next to the bolt so vise grips have been unsuccessful. I also cant get a straight shot with a drill to drill the bolt out. Anyone have any ideas?
Phils is offline   Reply With Quote
Old 06-04-2011, 12:09 AM   #2 (permalink)
Have you tried goose neck pliers?
Old 06-04-2011, 02:02 AM   #3 (permalink)
xGS
xGS's Avatar
Check with your local hardware/home-improvement/auto-parts store for sockets specifically designed to remove rounded-off bolts.
Just one example: Bolt Extractors - Tools - IRWIN TOOLS
Old 06-04-2011, 11:24 AM   #4 (permalink)
Thanks you two. I really appreciate the advice. I will check into it!
Old 06-06-2011, 01:25 PM   #5 (permalink)
Site Sponsor
hondacuraplanet's Avatar
I'd try a pipe wrench first. It will automatically increase positive pressure on the bolt as you try to turn it.
www.oemacuraparts.com
Old 06-07-2011, 07:15 AM   #6 (permalink)
Don't remove it till you have a replacement plug to put on in it's place. Get a new washer as well.
SD16 is offline   Reply With Quote
Old 06-09-2011, 02:09 PM   #7 (permalink)
lefty loosey righty tighty
Satch is offline   Reply With Quote
Old 06-09-2011, 02:26 PM   #8 (permalink)
no offense, but are you sure you're messing with the correct bolt? there is a lot of room around the drain bolt (you say there isn't any room) to use vise grips from the bottom. One thing that has worked for me in the past on rounded bolt is hammer on a socket this is slightly too small (like a cheap SAE socket). then use a breaker bar to turn it. you will probably not be able to get bolt out of socket so make sure you have new drain bolt and don't use an expensive socket.
schumi is offline   Reply With Quote
Old 06-09-2011, 03:20 PM   #9 (permalink)
I am still trying to figure out how an oil drain plug gets rounded off.
Old 06-10-2011, 01:38 PM   #10 (permalink)
Thanks you guys. The bolt extractor worked like a charm. One of the most expensive oil changes I've ever done.
Old 06-10-2011, 02:39 PM   #11 (permalink)
It it's not broke, you're not trying hard enough.
-Red Green
2007 Pilot LX
2004 Suzuki V-Strom
Old 06-10-2011, 10:21 PM   #12 (permalink)
The same way my father in law does it, using standard sockets and box wrenches on a metric vehicle. 14mm or 1/2 inch? Who cares, close enough is close enough. He never will understand the difference.
2005 LX 4wd
OEM accessory roof bars
OEM nerf bars
OEM rear splash guards
2006 OEM 4wd emblem
Garmin GPS
Aftermarket tinted windows
OEM accessory fog light kit
OEM accessory cargo cover
Silver painted grill
Acura stainless exhaust tips
KYB GR2 struts/shocks
Curt 13328 Hitch
