Engine taking time to turnover - Honda Pilot - Honda Pilot Forums
Old 04-19-2011, 06:46 AM   #1 (permalink)
Question Engine taking time to turnover
2004 Pilot with 60k miles. Of late it has been taking time to turn over on the first start. Takes about 4-5 seconds. The second crank is normal. I had battery changed 3 months ago. Weather is not cold. No idiot lights on dash. I am thinking fuel pump or timing belt ... any ideas ?
bonedoc is offline   Reply With Quote
Old 04-19-2011, 08:56 AM   #2 (permalink)
I would bet a dirty injector is sticking and causing a loss of fuel pressure when off.
First, when you start, actually count the seconds, because even one or two can seem like 4 or 5.
Next, try turning on the ignition and waiting a second or two before cranking.
Old 04-19-2011, 05:59 PM   #3 (permalink)
Could be the starter going bad.
2005 LX 4wd
OEM accessory roof bars
OEM nerf bars
OEM rear splash guards
2006 OEM 4wd emblem
Garmin GPS
Aftermarket tinted windows
OEM accessory fog light kit
OEM accessory cargo cover
Silver painted grill
Acura stainless exhaust tips
KYB GR2 struts/shocks
Curt 13328 Hitch
Old 04-19-2011, 06:36 PM   #4 (permalink)
roarkrd's Avatar
Also, check and make sure your cables are in good shape, as well as a good having a good connection with the posts. I had this problem earlier this month. I also had a 3 month old battery.
