Today my Pilot won't start! - Honda Pilot - Honda Pilot Forums
 1Likes
post #1 of 18 (permalink) Old 03-13-2011, 12:11 AM Thread Starter
OK, my '05 EXL has always been uber-reliable, with just over 88k on the clock. Today, I started it up and moved it down my driveway so I could mow the lawn - backed it up a distance of no more than 20 feet and turned it off.
A half-hour later, I got in to move it back, and the Pilot would not start. All the dash lights work, accessories work, gages operate properly, the fuel pump pressurizes the system - but when I turn the key to "start" position (III), nothing. The starter does not spin, the solenoid does not engage.
At first I thought my battery had gone bad, so I tried jumping it (from my Studebaker... that was an interesting sight). No luck. Called HondaCare and they sent out a service tech, HE tried jumping it - no joy. Played with the key a bit, made sure the immobilizer wasn't playing dirty... and no go.
I pushed the car back down the driveway (no dealer service open 'til Monday), but I can't help thinking this is something simple. Any ideas?
Showbizkid is offline
post #2 of 18 (permalink) Old 03-13-2011, 11:19 AM
samc's Avatar
As you said, why not start there? take out the starter and have it tested.
samc is offline
post #3 of 18 (permalink) Old 03-13-2011, 11:30 AM
Try starting in park & neutral.
Can you bang on the starter solenoid with a hammer or long metal bar WHILE someone turns the key to "start"?
Can you hook up a test light to the small wire on the starter? If it lights up when turning the key to "start" and the starter doesn't spin, then the starter is the problem. If it doesn't light up when the key is turned, then there is a problem elsewhere, like the immobilizer or neutral safety switch.
2010exl is offline
post #4 of 18 (permalink) Old 03-13-2011, 01:54 PM Thread Starter
Thanks for the suggestions.
Stoopid question, though - where the heck is the starter? I was under the car yesterday looking and I cannot find it
post #5 of 18 (permalink) Old 03-13-2011, 02:08 PM
Super Moderator
Rocky's Avatar
Assuming its not the battery, I'm thinking that either something has happened to the shifter which thinks its in D or R rather than P or N and therefore it wont allow the car to start.
Alternatively the brake light switch has failed resulting in the interlock not allowing you to start the car.
Cycle the shifter through its range of positions and try again in N then D.
If no joy, have someone check the brake lights to see if they work.
2005 Pilot Exl Res
2016 CRV Touring
Rocky is offline
post #6 of 18 (permalink) Old 03-13-2011, 02:36 PM Thread Starter
OK, I did as suggested and ran the shift lever through all positions several times. Tried to start it in Neutral as well as Park. No luck; I had my wife step on the brake while I observed and both brake lights are operative.
post #7 of 18 (permalink) Old 03-14-2011, 02:11 PM
Showbizkid, I am in San Diego also (Carmel Valley) and the starter is located closer to the top back driver's side part of the engine from under the hood, closer to the firewall, kind of close to the brake booster. Can't miss it. Listen to 2010exl, he has the correct procedure for diagnosing (now that you have checked out the shifter and have elminated the battery as the cause). You may want to also check the volts on the battery just to be sure, should be 12.5 volts or so. Also, I assume you have replaced the battery if it is the original. Most original batterys from 2005 need to be replaced by now. They only last 5-6 years.
2005 LX 4wd
OEM accessory roof bars
OEM nerf bars
OEM rear splash guards
2006 OEM 4wd emblem
Garmin GPS
Aftermarket tinted windows
OEM accessory fog light kit
OEM accessory cargo cover
Blacked out grill
Acura stainless exhaust tips
KYB GR2 struts/shocks
Curt 13328 Hitch
mclairmo is offline
post #8 of 18 (permalink) Old 03-14-2011, 05:07 PM Thread Starter
Thanks for all the input guys. I tried a couple things and no joy, so it was off to the dealer on a flatbed this AM (glad I bought HondaCare). Waiting for the call, now. I'll post the outcome for posterity (Wilhelmina Posterity; very nice lady!) when I find out.
post #9 of 18 (permalink) Old 03-14-2011, 08:33 PM
Good luck.
2005 LX 4wd
OEM nerf bars
2006 OEM 4wd emblem
Garmin GPS
Blacked out grill
Curt 13328 Hitch
mclairmo is offline
post #10 of 18 (permalink) Old 03-14-2011, 09:14 PM Thread Starter
Just got the call from Hoehn Honda... it was, in fact, the starter itself. Completely crowbarred internally. Once again, glad I popped for the HondaCare upfront... you don't expect a starter to go at 88k!
post #11 of 18 (permalink) Old 03-14-2011, 09:22 PM
samc's Avatar
What do you mean crowbarred internally? Can you have them save the starter so that you can take it apart?
I just want to see if the solenoid froze up or perhaps the spinning part broke down somehow.
samc is offline
post #12 of 18 (permalink) Old 03-14-2011, 09:22 PM
Glad I have Honda Care until September 2014 on my 2008.
OhioBobcat2000 is offline
post #13 of 18 (permalink) Old 03-14-2011, 09:24 PM
macphanatic's Avatar
Glad it was something simple.
FWIW, I didn't expect to have to replace a battery on a 3.5 year old vehicle. All our Fords got 6 plus years out of each battery.
macphanatic is offline
post #14 of 18 (permalink) Old 03-14-2011, 11:15 PM Thread Starter
Sorry, electrical jargon Means dead short - armature winding must have shorted out.
post #15 of 18 (permalink) Old 03-15-2011, 03:01 PM
That's very odd after only 88,000 miles. Wonder if it got wet ever or soaked in oil somehow.
2005 LX 4wd
OEM nerf bars
2006 OEM 4wd emblem
Garmin GPS
Blacked out grill
Curt 13328 Hitch
mclairmo is offline
