Vibration in Steering - Honda Pilot - Honda Pilot Forums
Old 03-09-2011, 09:17 AM   #1 (permalink)
Angry Vibration in Steering
My 2004 Pilot has a bad Steering Wheel Vibration beginning at 70 MPH..have new tires, balance 5 times, load balanced etc..no help. I heard there was a stabliezer designed to help...bolted on back of chassis? can someone please help.
Also tires are too stiff, wheel dirty, bad drive shafts!!!
JEFFDUBE is offline   Reply With Quote
Old 03-09-2011, 11:51 AM   #2 (permalink)
Please continue discussion on the existing thread
Vibration/shimmy experiment -- MDX rear subframe brace retrofit
Old 03-09-2011, 01:32 PM   #3 (permalink)
I don't see any mention of alignment check. I'd check the alignment, ball joints, tie rods and suspension arms.
My last car had a vibration at highway speeds, it turned out to be a worn bushing in the lower control arm.
Old 03-09-2011, 02:26 PM   #4 (permalink)
xGS
xGS's Avatar
Did the vibration start right after you got the new tires?
What make and model of tires did you get?
When they did the road force (load) balancing, did they (re)position the tires on the rims to get the minimum amount of road force?
Even if the new tires were road force (load) balanced, the net road force may still be too high to avoid vibration.
Do you know what the amount of net road force was for each tire/wheel after balancing?
Otherwise, if it's another mechanical issue, here's a chart to help you diagnose the problem:
http://www.tirerack.com/images/tires/vibechart.pdf
Old 03-09-2011, 02:53 PM   #5 (permalink)
Also check the steering column out itself. Maybe it's loose somewhere. It's just bolted on under the dash with a couple bolts and bolted to the steering linkage and those bolts can come loose.
2005 LX 4wd
OEM accessory roof bars
OEM nerf bars
OEM rear splash guards
2006 OEM 4wd emblem
Garmin GPS
Aftermarket tinted windows
OEM accessory fog light kit
OEM accessory cargo cover
Silver painted grill
Acura stainless exhaust tips
KYB GR2 struts/shocks
Curt 13328 Hitch
