vsa problem PLEASE help - Honda Pilot - Honda Pilot Forums
Old 01-26-2011, 03:41 PM   #1 (permalink)
Default vsa problem PLEASE help
VAS on my 2006 honda pilot stays on, will go off when turn key off/on the come back on sitting still or sometimes 3 miles down the road. scanned with a snap-on ethos and got codes 61-1 battery voltage low, 66-1 brake pressure sensor failure, 68-1 brake switch failure,
jimmyjr000 is offline   Reply With Quote
Old 01-26-2011, 04:19 PM   #2 (permalink)
I would load test the battery to see if that is the culprit. A weak battery does weird things to the Pilot.
Old 01-26-2011, 04:32 PM   #3 (permalink)
Agreed. If you are running the original factory battery, get it out now, before it strands you in the middle of the snow storm.
