2005 pilot overheating - Honda Pilot - Honda Pilot Forums
Old 01-20-2011, 11:50 PM   #1 (permalink)
Default 2005 pilot overheating
i have a 2005 pilot thats overheating. i live in minnesota and its -13 below and this is the first time that this has happened. ive been through cold winters before with her and have never had this problem. i did test the rad hoses and the top hose is super hot and the bottom hose is cold. you guys think its the thermostat? any info is appreciated. thanks
6pucker is offline   Reply With Quote
Old 01-22-2011, 07:34 AM   #2 (permalink)
Underdog's Avatar
It certainly sounds like a coolant circulation problem.
The thermostat is the easiest part to diagnose so I would start there.
Good Luck
Underdog is offline   Reply With Quote
Old 01-22-2011, 02:51 PM   #3 (permalink)
changed out the thermostat and all seems to be fine again. although i must say that it was the most troublesome thermostat change that i have ever encountered.
Old 01-22-2011, 02:55 PM   #4 (permalink)
Sounds like 1) thermostat, but 2) could be frozen, thus, blocking flow. Have you had antifreeze tested to see what temp its good for?
- Colgen Full front end bra
- Sherpak Go-7 luggage pack
- AVS sun roof windflector
