I've read everything I can on the ANC induced drumming noise on my 2006 EX-L. I've turned the system off via the no. 1 & 6 preset buttons on the radio, and the noise goes away. It seems to reset itself when I restart the car.
Has anybody learned how to fix or permanently disarm the system? |
Here's the Service Bulletin that addresses your problem. Did hear of someone that had the Dealership disable the ANC but didn't say how.
Reference Bulletin 06-092, 12/22/06 Service Bulletin © 2006 American Honda Motor Co., Inc. All Rights Reserved ATB 34078 (0612) 1 of 1 CUSTOMER INFORMATION: The information in this bulletin is intended for use only by skilled technicians who have the proper tools, equipment, and training to correctly and safely maintain your vehicle. These procedures should not be attempted by do-it-yourselfers, and you should not assume this bulletin applies to your vehicle, or that your vehicle has the condition described. To determine whether this information applies, contact an authorized Honda automobile dealer. December 22, 2006 06-092 Applies To: 2006 Pilot All LX 2WD models 2007 Pilot LX 2WD models from VIN 5FNYF2...7B000001 thru 5FNYF2...7B006392 Booming or Humming Noise From Speakers While Driving SYMPTOM A booming or humming noise is heard from the speakers while driving with the radio on or off. PROBABLE CAUSE A faulty ANC (active noise control) unit. CORRECTIVE ACTION Replace the ANC control unit. PARTS INFORMATION ANC Control Unit: P/N 39200-STW-A02 H/C 8563413 WARRANTY CLAIM INFORMATION In warranty: The normal warranty applies. Operation Number: 0101C9 Flat Rate Time: 0.6 hour Failed Part: P/N 39200-STW-A01 H/C 8159055 Defect Code: 03217 Symptom Code: 04201 Template ID: 06-092A Skill Level: Repair Technician Out of warranty: Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Parts and Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work. DIAGNOSIS 1. Start the vehicle. 2. Turn the radio on, and make sure it operates normally. 3. Turn the radio off. 4. Press and hold the preset buttons number 1 and number 6, then press the VOL push PWR button. The audio system enters its diagnostic mode and Diagnosis (or Diag) appears on the display. Release the preset buttons. 5. Press the number 1 preset button. ANC ON appears on the display. 6. Press the number 1 preset button again to turn the ANC OFF. You should hear a humming noise coming from the speakers for about 60 seconds. NOTE: To turn the humming off, press the number 1 preset button to turn the ANC ON, and wait for the hum to stop. Press the number 1 preset button again to turn the ANC OFF. Repeatedly pressing the number 1 preset button cycles the audio unit ANC ON and ANC OFF, but the ANC control unit wont hum until the ignition switch is turned on and off, and you put the audio system back into Diagnosis mode. When the ignition switch is turned on and off again, the audio system defaults to its ANC ON mode. 7. With the ANC OFF (audio unit on), test-drive the vehicle as described by the customer. If you cant reproduce the booming or humming noise, go to the REPAIR PROCEDURE. 8. If you can still hear the booming or humming noise, disregard this bulletin and do the ANC troubleshooting in the service manual. REPAIR PROCEDURE 1. Replace the ANC control unit. Refer to page 22-345 of the 200607 Pilot Service Manual, or Online, enter keyword ACTIVE and select Active Noise Control Removal/Installation (2WD) from the list. 2. Test-drive the vehicle to confirm the repair. |
Thanks Pete. Do you know where the amplifier is located? The microphone is located about in the center of the headliner. I can't figure out how to remove it to unplug it. Any ideas?
I've been doing a search for conversation mirror as those instructions would help-not easy doing it on a phone!.
on the Collegehillshonda site under 03-05 Pilot there are instructions for installing homelink. Follow those instructions to take the sunglass etc holder apart-
I understand the Active Noise Control Unit is behind the radio so quite a job to get to it, particularly if you don't have an Overhaul Manual for removal procedure.
The SB states that if you are out of warranty, which you obviously will be, the "Goodwill" factor may apply. Maybe get it done a little cheaper or get the Dealership to disable it for you. Worth a try, so best of luck. Pete. |
