Not sure what is going on here. 2004 Pilot with 83k miles. Two nights ago, I noticed that the lights were sporadically blinking off for a fraction of a second. Probably happened 5 times within a 25 min period. Drove it again last night and it happened once in a 10 min period. When I got home last night, I tried to lock the car with the key remote and it would not lock. I opened the car door, and no lights came on. Inserted the key into the ignition and it was completely dead. About 20 minutes later, I went out and tried it again and everything was normal - started just fine. Just went out this morning and once again, it started just fine.
I'm concerned that it will strand us somewhere, any thoughts? |
Double check you battery cables.
IF they are not tight at the battery and will not tighten, the ends (or whole cables) need to be replaced. Also check the other end, but problems there are far less common.
signs that your battery is nearing its end. had the same issues when it finally died(oem battery).
It was the battery cables. Not sure why I didn't look there first. Positive was lose. Cleaned and tightened them both up and everything seems to be working fine. Thanks for the help!
