I have a 2005 Pilot w/65000 miles about once a day when I go to start it It makes the sound like the starter is not lining up with the fly wheel then next try it starts right up. Anyone else have this problem?
2005 Honda Pilot EX |
If your battery (and connections) are Okay, it is probably the solenoid sticking that engages/disengages the starter motor from the engine. Don't think the solenoid is available separately, so you probably just have to replace the starter with a rebuild. It will probably get progressively worse, so you could live with it awhile until it gets to be a real problem.
But I'd start with the battery which is cheaper, simpler, and easier to replace. If the battery is older or at all suspect, I'd start all electrical repairs with a new battery. If the engine turns over a little less lively than it used to, that's a dead ringer for a battery going south. - Mark Last edited by whizmo; 09-06-2010 at 07:28 PM. |
I agree with both John G and Whizmo. Check the terminal clamps on the battery post.
When I did my most recent door mod I had to disconnect the battery. When all was done I could not get a good tight fit on the battery post. I would have never caught this, if not for doing the door mod and this could have definitely lead to intermittent starting problems. Possibly even failure on the highway. I used washers to fix the situation quickly but they also make battery shims that fit over the posts. Hope this is the problem your having.
____________ 2005 EX-L 4wd WEATHERTECH* Floor liners, cargo liner, 3rd row all weather mats and bug/wind deflector (Direct Order). CURT*Trailer hitch /harness/Transmission and Power steering coolers (etrailer). OEM *Crossbars and rear splash guard (HandA). OEM* Foglights (Ebay/yourkeylessremote). DEI * 452t Automatic Door Lock Modification (Sonixelectronics). MAXXIMA*M09300 Side Marker LED light Modification (Partssystems). Coffee ! Is The Planet Shaking or Is It Just Me ? Last edited by cofetym; 09-06-2010 at 10:03 PM. |
When you do, clean off any gunk from both sides of the terminal. Assume its a fairly new battery in good condition.
Site Sponsor
That said, the two most likely scenarios are worn teeth on the very edge of the solenoid, or a sticking solenoid. Depending on your skill level, and time available, you may be able to remove the starter and accurately diagnose the issue, I've done this several times and can walk you through it if interested. Or, simply replace the starter
![]() www.oemacuraparts.com Remember to visit www.hondacuraplanet.com for your accessories needs! See our Pilot monthly special here! http://www.hondacuraplanet.com/mm5/m...tegory_Code=SP |
