Hello All,
The AC is not working in my 2003 Pilot. The blower runs, but nothing comes out the front vents. Cool air is moving from the rear unit. I can hear the fan changing speeds as I increase the setting, but nothing from the vents. I selected each of the settings (e.g., defrost, bottom, etc.), but get nothing. The door of the vehicle was left ajar all night with the key in and switched to postion 2, but everything worked fine after jump-starting and a 40 minute drive, but when we started back up we had the problem. Any help appreciated. Thanks |
Since the batter died, I would TRY disconnecting the battery and letting everything reset.
Since The fan blows I bet it is one of the flaps that directs the air. If it is only the rear fan moving then I bet it is the front fan speed control transistor module.
