Hi, we somehow broke the plastic piece covering the side of the seat track on both the driver's side front and middle seats (see pictures). The driver's seat looks kind of involved since it has the seat controls on the side. We have a 2003 Pilot, by the way. No idea if these pieces are still available or not. Hopefully they replaced them with something less cheap in the newer Pilots.
Same thing happened to my 03, driver's seat. Picked up the piece at Honda and installed it myself. Remove the trim by removing the 3 (I think 3) screws that secure it. You will then have to remove the electric switches for the controls, but before you do that you have to remove the plastic controls from outside of the trim, gently pull them off with your fingers, or a screw driver if you need a little leverage. Install the switch housing in the new trim and reinstall. 10 - 20 minute job, cheers
Go to the parts section of the Majestic Honda website. Dig in to find the parts page you need complete with part numbers and prices!
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2004
Majestic Honda West Warwick - Parts & Accessories | Honda Replacement Parts Kingston | Discount Auto Parts in Warwick
System Name\Component : FRONT SEAT (L.) (POWER) (- 05) 81638-S0X-A22ZG COVER, L. FR. SEAT RECLINING *NH361L* CF GRAY $27.35 Image 17
04' Sage Brush Pearl EX Chrome Side Steps (OEM), Rear Splash Guards (OEM), Cross Bars (OEM), Chrome Exhaust Tips (OEM), Cargo Net (OEM), All-Season Floor Mats (OEM) WeatherFlectors from WeatherTech (Dark), FormFit Air Deflector, Cloud-Rider Mirror SS Mesh Grille Inserts, Full Size EX Spare, 3m Protective Tape, Wwong's Pilot Pads, Chrome Accessory Logos, Clear Door Edge Guards. Free brushless car wash anytime. 09' Honda Ridgeline RTL, Mocha w/Black Interior 99' Honda Shadow ACE 1100C2 |
Middle seat cover
81758-S3V-A12ZD COVER, L. MIDDLE SEAT SLIDE *NH361L* CF GRAY $19.25 Item 25
Way to go Pilotmatt!!!!
Happy to help out fellow Piloteers!
He needs to make sure to order the correct color though.
I just spend a few bucks at my friendly local independent hardware store to fix mine. I don't remember the exact parts, but it involved some nylon spacers, some washers and some bolts. The nylon spacers went into the hole or "cone" where the bolt goes to give some support, then a washer, then a longer bolt to go through all that to the threaded hole in the frame.
You'll have to play around with the sizes, or if you give me a day or three, I can undo mine and make a list for you. Maybe even take a photo or two. It's holding strong so far, and it's probably been a year or so since I did it. And now I try to slide in and out in such a way as to not put so much downward pressure on the side of the seat and that trim piece.
Thanks guys, especially Matt! I have seen Manchester's web site before, but finding the right diagram is baffling to me. Thanks for the help.
![]() By the way, the middle seat cover in the color saddle is $62!!!! Glad I have gray. lol |
Glad I could help and welcome aboard!
#11 (permalink) | |
I did this repair about a year ago and it is still solid.
See attached sketch and prior post. Busted drivers seat control panel
Here's what I did -- it's very simple -- same for both holes:
#12 x 1-1/2" panhead sheetmetal screw 1/4" SAE flat washer 1/2" OD, 0.257" ID, 1" long nylon spacer Not quite as elegant as belundy's method, but pretty good if you don't want to deal with making a tapered dowel. I suppose you could also use a number of shorter spacers with varying ODs. I'm pretty sure I first tried a bolt with the same threads as OEM, but it just wouldn't go in for some reason, so I ended up with the sheetmetal screws.
#14 (permalink) | |
I'll try your fix, thanks onu2002
#15 (permalink) |
![]() ![]() ![]() ![]() ![]() Join Date: Sep 2003
This was apparently a weak point on the '03. I had mine replaced under warranty fairly early in the game.
Larry
2010 CR-V Urban Titanium Metallic EX-L, Nuvi 2460LMT GPS, also '07 Accord EX-L. Former proud 7 year owner of 2003 Pilot EX-L. |
