Random Rough Idle - Honda Pilot - Honda Pilot Forums
Old 07-15-2010, 09:42 PM   #1 (permalink)
Default Random Rough Idle
Have a 2004 EXL with about 36K miles. Experiencing a random rough idle or a miss when at a stop light. Seems to run fine then every now and then, I feel a miss. No error codes are being thrown. Experienced a similar problem when it would run rough at 33K miles, but took it in and dealer said it was a bad plug. Threw an error code that time. Did a search and didn't find anything similar. Any ideas?
Mike
2004 Honda Pilot EX-L Nighthawk Black Pearl
2002 Honda Odyssey EX Taffeta White
s6skuzy is offline   Reply With Quote
Old 07-15-2010, 11:07 PM   #2 (permalink)
Have you done a search for "EGR valve"? It sounds like you may have a bad one.
Old 07-15-2010, 11:14 PM   #3 (permalink)
cwa107's Avatar
That was my thought as well. Very common problem I've seen here a time or two.
2013 Nissan Pathfinder SL Premium, Dark Slate
2010 Honda Pilot EX-L 4WD (traded)
Old 07-16-2010, 06:51 AM   #4 (permalink)
Thanks...
I did search for that, but it isnt throwing an error code. It appeared that most had an error code thrown. Unless, this is just the start of it and will throw one soon...
Mike
Old 08-17-2010, 07:52 PM   #5 (permalink)
Default Back again...
Used some fuel injector cleaner (gas additive) and it cleared up the problem for about a month. Filled up with Sams gas and its back again. This time the MIL and VM light is on. Took it to AdvancedAuto and its throwing codes P0305 (Misfire on 5), P0306 (Misfire on 6), P0300 (Random multiple misfires), and P1399 (Manufacturer Ignition System Code).
Taking it to the repair shop tomorrow. Any ideas/guesses?
Mike
Old 08-17-2010, 08:32 PM   #6 (permalink)
No chance you're getting misfires from bad plugs this early, unless you're using leaded gas or running diesel in it. I'd go with a computer/emissions valve issue to start. Take the codes to the dealer and see what they say. Then, if you don't like their answer, find the best indy mechanic in Detroit and go there for diagnosis.
OhioBobcat2000 is offline   Reply With Quote
Old 08-17-2010, 08:49 PM   #7 (permalink)
Default Inspected and cleaned up ports
Inspected the ports and it wasnt bad. Some carbon around two ports, but nothing close to being clogged. Cleaned it up and put it back together. Still same rough idle.
Mike
Old 08-17-2010, 09:01 PM   #8 (permalink)
Had it in the Dealer for a similar issue back last fall and they diagnosed it as a bad plug on number 2. Was under extended warranty at the time but they wouldnt cover it stating its a wear out item. Cost $140 if I recall to repalce one plug and to be diagnosed. Only has 37K miles on it now, but agree its a tad early for plugs.
Mike
Old 08-17-2010, 09:10 PM   #9 (permalink)
cwa107's Avatar
The EGR valve is a fairly common failure in the early Pilots and can definitely cause misfires.
Have a look at this thread:
check engine light-need advice!!
...and this one...
Engine Light: Misfire...help!
If you Google those codes in conjunction with the words "Honda Pilot", you'll see the same thing turn up time and time again.
Old 08-17-2010, 09:22 PM   #10 (permalink)
Tempted to replace the ERG, but looks like there about $100 at AdvancedAuto. Hate to replace it with no error codes indicating there is an issue with it.
Mike
Old 08-17-2010, 09:24 PM   #11 (permalink)
rocky's Avatar
Surely its not the gas......I'm amazed at a 04 pilot with so few miles....
Old 08-17-2010, 09:35 PM   #12 (permalink)
Well, its possible its the gas this time around... Could be getting some bad gas from Sams every now and then. Tried to call them to see if there were any other complaints, but they were closed already.
Mike
Old 08-17-2010, 10:28 PM   #13 (permalink)
cwa107's Avatar
You might want to try cleaning it first:
How to Clean an EGR Valve in a Honda | eHow.com
Old 08-17-2010, 11:02 PM   #14 (permalink)
Eh....bad gas from a warehouse club seems unlikely. While I used to be a gas snob, I now realized (and researched) that as long as it's a large, well-maintained, quick turnover station, bad gas shouldn't exist. I buy gas from Costco once a month and can't complain.
However, you may be correct. I still say unlikely.
Old 08-18-2010, 12:49 PM   #15 (permalink)
You probably shouldn't be troubleshooting something that's a "consumable" like spark plugs. If it were myself, I'd buy new plugs and replace them. Just because you can run the plugs for 100k miles, doesn't necessarily mean you should. Also, it should eliminate that as a potential cause and it couldn't do anything but help your cause.
Good luck!
-Sam
samelcamel is offline   Reply With Quote
