Honda Pilot - Honda Pilot Forums (http://www.piloteers.org/forums/)
-   Problems (http://www.piloteers.org/forums/14-problems/)
-   -   Repairing rear power window (http://www.piloteers.org/forums/14-problems/22974-repairing-rear-power-window.html)
Park 12-01-2008 08:24 PM
I have a 2005 Pilot and today the rear passenger side window rolled all the way down and will not come back up. After removing the door panel and feeling around inside the door I found a wire from (I think) the motor that is just hanging there. The motor responds when you push the button but makes a grinding noise and obviously the window does not go up or down.
Does anyone know if the wire I found should be connected back to the motor? Is the motor bad? Is it something else completely?
The wire I am referring to is not an electrical wire. Thanks for any help.
iglesias 12-02-2008 12:07 AM
Re: Repairing rear power window
Some part of the window up/down mechanism probably broke and the loose wire is the result. Unless you have a repair manual and feel comfortable doing the repair, you'll have to get the dealer or independent repair shop/body shop to fix it.
Rocky 12-02-2008 07:34 AM
Sounds like the regulator that moves the glass up and down has broken.
Would happen on my truck. The only cure is replacement.
Park 12-04-2008 10:59 AM
I pulled of the other door panel to see how it is setup. It is really hard to see but I can tell the metal wire is supposed to be connected somewhere. The end of the wire has a round ball attached to it and it doesn't look like it has "broken" off but maybe just came loose??
If anybody can point me in the right direction of a repair manual, I would greatly appreciate it.
Thanks for the replies.
chiph 12-08-2008 04:46 PM
Helm sells the Honda factory service manuals
http://www.helminc.com/helm/product2...FT1BCNC8G11FG0
Yes, it's expensive at $70, but I have one for my CR-V and it's awesome -- there is *so* much information in there. Totally worth the cost.
You might find CD-ROM versions for sale on Ebay. Stay away from them as they are scanned from the manual, and are illegal copies.
Chip H.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
