Remote(Lock/Unlock/Panic) key not working - Honda Pilot - Honda Pilot Forums
post #1 of 10 (permalink) Old 08-28-2008, 03:10 PM Thread Starter
I bought a honda pilot 2005 EXL from an used car dealer.I noted the remore key was not working.The dealer said could be the battery needs to be replaced. Then i came home, changed the battery(same model # battery), but still not working. Dealer who sold the car is 150 miles away. So cant go back to him. Not sure if this key needs re-programming or something
kiran654 is offline
post #2 of 10 (permalink) Old 08-28-2008, 03:25 PM
charly's Avatar
Welcome to the HP>org fam.
too bad you remote don't work, what makes it worst is the fact the he is far far away. Buty try bringing it to a HONDA stealer.. Just to see what they might say about...or test it..etc...And don't forget to post some pic's\\
at least just to se what color you got...
"Sogood"
HONDA PILOT LX "07
charly is offline
post #3 of 10 (permalink) Old 08-28-2008, 03:29 PM
Super Moderator
sblvro's Avatar
before you bring it to the dealer, check if your central lock is working. if all 4 door locks work when you press the unlock and lock button of your driverside door switch then yes it must be the remote. if one of more doorlocks is/are not working then you need to change the locking mechanism before you can have your remote working again. GL
2003 black onyx Lexus IS300
2006 evolution IX MR(RIP)
sblvro is offline
post #4 of 10 (permalink) Old 08-28-2008, 03:42 PM Thread Starter
I bought a black Honda pilot EXl 2005. Inside Beige leather.
The driver side central locking switch is working fine.
It just the remote lock/unlock.
Also my TPMS indicator is not not turning off.Its showing up after like 10-15 minutes i drive. Got to test the tire pressure too when i take it to the dealer.
kiran654 is offline
post #5 of 10 (permalink) Old 08-28-2008, 11:23 PM Thread Starter
i went to Good year tires, and they told that valve stems are missing snd because of corrosion all 4 TPMS sensors need to be replaced. They told it costs 325(parts)+85(for labor). For now they re-set the indicator though. Since TPMS indicator problem was existing when i bought from dealer, i need to ask the dealer.
not sure what I can do if he says he will not bear the expense for fixing TPMS problem.
kiran654 is offline
post #6 of 10 (permalink) Old 08-29-2008, 04:30 AM
iivtecracerii's Avatar
just reprogram the remotes. the procedure can be found on this site, and im 99% sure its in the manual too.
iivtecracerii is offline
post #7 of 10 (permalink) Old 05-17-2012, 03:05 PM
What fixed remote lock/unlock
a0206066 is offline
post #8 of 10 (permalink) Old 07-20-2012, 07:42 PM
I have a problem with the remote keys - they will not lock or unlock the doors. It happened a few days after installing a new car battery. I initially thought it might be the key's battery, but my wife's car key remote worked for a few days before it also quit working. I was wondering if I might have done something to cause this to happen?
jimintx is offline
post #9 of 10 (permalink) Old 01-04-2014, 04:28 PM
solution needed
Looking every where to find an answer to the remotes not working. Please help. ty.
vshark7 is offline
post #10 of 10 (permalink) Old 11-30-2014, 03:13 PM
Common issue. Replace battery, clean contacts. Verify remote light comes on...
Yes for light, check with car...if it doesn't work..try re-programming
No on light... Replace remote
Seems like a fault in the OEM design. Have seen this a lot.
get the newly designed circuit boad.
ovnisf.com is offline
