Steering Wheel scraping sound - Honda Pilot - Honda Pilot Forums
post #1 of 25 (permalink) Old 11-06-2006, 09:53 PM Thread Starter
Since it started to get cold my steering wheel has a scraping sound when turning hard right or left (06 ex pilot). I brought it in for a service saturday and they heard it but did not have tijme to deal with it that morning and I have to bring it back. Anyone else have this problem?
lizzard1 is offline
post #2 of 25 (permalink) Old 11-07-2006, 08:43 AM
Yes, I started hearing this sound recently.
Slow speeds, right or left. It's not the brakes as far as I can tell. Anybody else?
'05/37K
'05 4WD w/Navi - Traded in at 136K for..
'08 EX 4WD - Alpine double din Stereo/Nav installed
beer4799 is offline
post #3 of 25 (permalink) Old 11-07-2006, 09:04 AM
jl_ss's Avatar
Re: Steering Wheel scraping sound
Is the noise coming directly from the steering wheel (inside the vehicle)? If so then it is probably the cable reel that allows the wiring to move (extend and retract) with the steering wheel. It was a fairly common problem on early MDXs. If not then nevermind.........
jl_ss is offline
post #4 of 25 (permalink) Old 11-07-2006, 08:24 PM Thread Starter
Re: Re: Steering Wheel scraping sound
Yes the noise is coming directly from the steering wheel inside where it turns. It happens with both left and right turns.
lizzard1 is offline
post #5 of 25 (permalink) Old 11-07-2006, 10:58 PM
Had the same problem with my 05 EX.I believe it is just the back of the wheel making contact with plastic on the column.Nothing too serious just annoying.
fighterpilot is offline
post #6 of 25 (permalink) Old 11-08-2006, 08:55 PM
Rapid Rob's Avatar
Either some plastic is rubbing in there or...
Another vote for cable reel.
Rapid Rob is offline
post #7 of 25 (permalink) Old 11-15-2007, 01:42 PM
Question steering wheel scraping sound
Just wondering if anyone has figured out a resolution to the scraping sound that comes from the steering wheel while turning it in cold weather. I have put up with this each winter since purchasing my '06 EXL in Nov '05. Doesn't sound serious, but it is annoying.
bbizot is offline
post #8 of 25 (permalink) Old 11-15-2007, 03:43 PM
I've been dealing with this issue for a long time now (about 14 months). After six dealer visits (five of which said "cannot duplicate noise"), we figured out the problem with the last dealer visit. It was the cable reel inside the steering column. Apparently Honda assemblers were a little careless and cranked the cable reel too tight, apparently smashing a portion of the reel.
I can say that after replacing the reel, my steering column is the quietest it's ever been. Have your dealer check the cable reel...
Steve
No longer with me: 2006 Honda Pilot EX - Sage Brush Pearl
My new fun: 2012 Volvo S60 T5 - Vibrant Copper
djstorm is offline
post #9 of 25 (permalink) Old 11-15-2007, 03:49 PM
Super Moderator
sblvro's Avatar
spray some silicone lubricant in between the steering wheel and the hub. it is just the contact points of the electrical pieces that connects to the hub. it is usually greased but in cold weather this happens or if your pilot is getting old(common).
2003 black onyx Lexus IS300
2006 evolution IX MR(RIP)
sblvro is offline
post #10 of 25 (permalink) Old 11-16-2007, 10:04 AM
I have this issue too on an 07 purchased in March. I have an appointment coming. Is replacing the cable reel a terribly invasive procedure? I'd hate to have them rip apart the steering wheel to fix a small issue only to create other problems such as misaligned plastic pieces, scratches, etc.
'07 Pilot EX Steel Blue Metallic
'96 Civic EX Black
'92 Integra LS Black (sold)
'88 Accord LX Gold (sold)
StarBlazer is offline
post #11 of 25 (permalink) Old 12-02-2007, 07:18 PM
I have this same issue on my O6 Pilot. I tried spraying silicone in the area however it didn't work. Anyone have any updates? Is there another fix without dealer intervention? Thanks.
hontor is offline
post #12 of 25 (permalink) Old 12-01-2008, 02:57 PM
guamaniac's Avatar
I have a similar issue with steering wheel noise in my 05 Pilot. I took off the steering wheel housing and sprayed some silicon onto the steering column nearest the steering wheel and just under a circular plastic ring. I could see deep inside some (shiny) grease so I added some more. I had to pry the circular ring toward the steering wheel to see the grease.
It helped quite a bit but I still have some noise, though.
UPDATE: After a week or so, the silicon is doing it's thing. The noise (and I mean noise) is only a fraction of what it used to be--maybe 10% or so. A much appreciated improvement!
Guamaniac
Guamaniac
B'ham, AL
guamaniac is offline
post #13 of 25 (permalink) Old 12-04-2008, 10:43 PM
TurboTurtle's Avatar
I had a similar noise on my 07'. The sound on mine was actually the plastic cover on the bottom of the steering wheel, which is used to gain access to unplug the airbag before taking off the steering wheel. I noticed if I took some electrical taped and taped around it, it stopped. A easy test would to be take the cover off and turn the wheel to see if it still makes a noise.
....nevermind...
Sports Fans...
http://sportsfactsandtrash.blogspot.com/
TurboTurtle is offline
post #14 of 25 (permalink) Old 10-10-2010, 09:56 AM
We have a Pilot EXL 2007 with 14.000 miles and it is making the noice from the steering column. Before this car we had a Pilot EXL 2007 with 21.000 miles- whitch after we had had it for about 2 weeks started making the noice. Took it to the dealer who changed the CABEL REEL under warante, because it had already been changed once within the past year, the car never made another noice from the steering again.
Trying to find out if there is any kind of recall on this???
LizaLauritzen is offline
post #15 of 25 (permalink) Old 10-10-2010, 06:17 PM
macphanatic's Avatar
Another vote for the cable reel. I had the same problem.
macphanatic is offline
