What is with all the resets on my 2006 EXL/Nav? - Honda Pilot - Honda Pilot Forums
post #1 of 28 (permalink) Old 06-05-2006, 11:56 PM Thread Starter
I have had this car about 1 month. 2 weeks ago, the automatic up/down window feature stopped working. I did the procedure listed in the manual to re-enable it.
Now today the Nav system is requesting the 4 digit code when I start the car?
Is this something I am going to encounter several times (or more) per year???
What could be causing this?
Thanks,
David
davidmac27 is offline
post #2 of 28 (permalink) Old 06-06-2006, 12:15 AM
A6Pilot's Avatar
Sounds like the battery is disconnecting from the electrical system sometime after the key is removed. All your symptoms can be caused by such an event, no matter how momentary.
One hopes your dealer has a skilled electrical system troubleshooter. Who knows, the solution may be as simple as replacing the battery. Let's hope so!
A6Pilot is offline
post #3 of 28 (permalink) Old 07-03-2006, 12:44 PM
myeboah's Avatar
the automatic reocde number is on one of the forms that the dealer might have given to you so find it and keep it well because you need it most of the time.
I love my pilot it makes me feel like flying
myeboah is offline
post #4 of 28 (permalink) Old 07-03-2006, 03:33 PM
Yup, sounds like some sort of a battery connection problem.
Current: 2011 4WD Touring - OEM Premium Running Boards - Hitch Haul - Thule Crossroads and Cargo Box
Previous: 2008 4WD EX-L NAV - Lots of OEM stuff, plus Vizualogic A-1250 Dual DVD Headrests - RGB converter for DVD on NAV screen - Air Lift 1000 - USA-Spec PA15-HON2 - DEI 452T Auto Locks - 114k trouble free miles.
First: 2005 EX-L NAV - A few mods and add-ons, 45k trouble free miles.
jcantanixon is offline
post #5 of 28 (permalink) Old 08-04-2006, 01:33 AM
I have this problem too. My windows have had to be reset about 5 times in the past 4 months, and once the NAV system had to have the code re-entered. We all understand that this is an intermittent power issue - but has any one had this specific issue on the Pilot found the cause of the momentary power loss, or been able to faithfully recreate the problem? I took my '06 in for service today, and they checked the electrical system and pulled out the radio to check for bad connections - but were not able to find anything wrong.
Thanks in advance to anyone who can help.
smsasaki is offline
post #6 of 28 (permalink) Old 08-04-2006, 02:13 PM
I've also had this issue on my '06 EX-L. I've owned the car for just over 7 months and the nav has reset twice and the auto up/down many more times. But, the two events seem to be independent of each other. Of the two times the nav reset, the window programming was undone once. The dealer replaced the nav and that seems to have cured the nav resetting (for now). But, the window resetting is still happening. I have an appt this Tues for them to again take a look at it.
While a minor issue (it certainly doesn't affect the safety of the car) it's very annoying!
Good luck to all of us!
Larry.
larrys is offline
post #7 of 28 (permalink) Old 08-04-2006, 03:35 PM
Humm, had my '06 since January and the NAV/Radio had reset ONCE. The Windows has not happened yet...
Seems there might be an electrical problem looming in some of these Pilots...
Has anybody talked to the Dealer regarding this yet???
<p><strike>'04 Sage Brush Pearl EX-L</strike> (Rolled/Totaled - Not our fault, was hit by redlight runner)
'06 Steel Blue Metallic EX-L 4WD w/ NAV
jlee2070 is offline
post #8 of 28 (permalink) Old 08-06-2006, 06:54 AM
jrinjax's Avatar
NAV Reset
I hopped in my Wife's car at the boat ramp yesterday and the NAV came up asking for the PIN number. I tried several numbers that were on stickers and cards, finally finding the right one and it booted up. I called the dealer, who said he had never heard of this, except with dead/disconnected batteries. I referred him to this site and suggested that he read it.
Her car has also had the sound system blank out two or three times and come back on by itself.
JR
06 Pilot EXL NAVI AWD RedRock Pearl
Ford F150 4x4
Allison XS-2003 GSE/Merc 2.5 SS
[3] '06 Honda AquaTrax Turbo F12X
[2] Vento Phantoms R4I
CR250 [2] CR80s XR100 PW50
"Confidence is the feeling you have right before you fully understand the situation"
jrinjax is offline
post #9 of 28 (permalink) Old 08-06-2006, 08:23 AM
mmmmark's Avatar
Speaking of the window vs. nav issue... One may be more sensitive than the other in regards to power failure.
For example, consider digital clocks in your home when the power blinks (microwave, alarm clock, etc.). When the power blinks, some go out immediately while others can take almost 5-10 seconds before they are affected. It has to do with the number and size of capacitors built into the component.
For the record, I think it is odd that Honda doesn't store more of this information in NVRAM so it is unaffected by power failure.
mmmmark is offline
post #10 of 28 (permalink) Old 08-07-2006, 08:06 AM
jrinjax's Avatar
Storage
Some stuff can't be stored in a eeprom or flash memory location if the amount [total number] of "writes" is substantial. The memory locations actually wear out after a certain number of writes. The flash memory is good if you are storing data that is accessed often, but "written" relatively seldom.
We have to be very careful not to accidentally write to one location or it will fail eventually.
RAM has no limitations on the "Writes".
JR
Ford F150 4x4
jrinjax is offline
post #11 of 28 (permalink) Old 08-07-2006, 08:58 AM
mmmmark's Avatar
Well, that is my point. The NAV ID seems like it can be written once to a non-volatile RAM location so that it isn' t easily lost on battery failure.
This also seems true with the window auto-down setup.
I think it was a poor design decision to allow this loss of settings when power is lost.
mmmmark is offline
post #12 of 28 (permalink) Old 08-07-2006, 11:35 AM
The Nav system isn't losing it's ID, it's the security code that needs to be entered after a power disconnect. They do this for security reasons. If the unit should be stolen, then the thief couldn't use it without that code. That's why it's also a good idea to not leave the radio/nav security code in the car.
And, you should notice that none of the radio/nav settings are lost after a power disconnect. It still remembers all of your radio station pre-sets and the address book on the nav is also all still there.
The window resetting I would guess is to allow faster installation of the assembly in the factory. They don't need to get it set exactly right. Then when the car arrives at the dealer, they then "tell" the window where the max open and max closed positions are located.
But, of course this is just my opinion .
Later,
Larry.
larrys is offline
post #13 of 28 (permalink) Old 08-08-2006, 09:31 PM
Larry.
I took my '06 in to the dealer (Stevens Creek Honda in Santa Clara, CA) today for them to look at the window resetting (becoming unprogrammed) and they called the "Tech Line" and were told to replace the "power window control unit and retest." The don't stock this part and have ordered it.
So, it's not solved but they are trying! But, even after they replace that part, it'll be a while until I know if it's truly fixed since this doesn't happen on a regular basis.
Later,
Larry.
larrys is offline
post #14 of 28 (permalink) Old 08-24-2006, 01:23 AM
I had both the Window and NAV problem. Another Pilot.org user told me that he had the same problem and noticed that the box on his fuse cover was loose. He opened it, pushed down on all the fuses and has not had the problem reoccur. I opened my fuse boxes and removed/reinstalled the fuses. I'll have to see how it goes, but up to now the problem has not repeated itself.
'06 Pilot EX-L/NAV (Sagebrush Pearl)
smsasaki is offline
post #15 of 28 (permalink) Old 08-24-2006, 01:45 AM Thread Starter
Yep that was me. I picked up the car and within a couple weeks I got hit by the auto up/down window feature not working. I reset it and it worked. Then a month later it did it again. I was looking at the engine compartment and noticed that the fuse box cover was not fully closed. I opened it and pressed down securely on all the fuses. A couple were only 90% pressed in. Since I did this, I haven't had any problems...
