DVD headrest install questions Honda pilot 2007 - Honda Pilot - Honda Pilot Forums
Old 02-08-2012, 10:56 PM   #1 (permalink)
Default DVD headrest install questions Honda pilot 2007
I have a Honda pilot 2007
I was trying to install the DVD headrests in them. I was trying to get ideas as to how to take the audio visual wires go from one seat to the other with out showing, any ideas to shove it below the carpet would be welcome.
Would it be easier to remove the back cover of the center armrest console?
Thanks in advance
Arnaar is offline   Reply With Quote
Old 02-09-2012, 09:29 AM   #2 (permalink)
pop the front and back trim pieces off of the bottom part of each seat, loosen up the 4 bolts for each seat and remove the center console. it may seem like a little more work but with that center console totally out of the way you have alot of room to work. with the seat bolts loose it also makes it alot easier to fish wires underneath.
Old 02-09-2012, 01:58 PM   #3 (permalink)
Yes, that's the best way to hide the wires completely. The shortcut is just to remove the back cover of the center armrest console and tuck the wires under that. Then they only show for an inch or so between the seats and the console. GL.
Old: 2005 EX-L NAV
Old 02-09-2012, 02:32 PM   #4 (permalink)
Here is the best thread on doing exactly what you want to do.
And more!
Vizualogic / NAV A/V Switch / DVD Changer Installation Instructions
Old 02-09-2012, 10:13 PM   #5 (permalink)
Awesome will try out taking the center console next weekend and see if it works
