Yakima Fairing or Windjammer experience? - Honda Pilot - Honda Pilot Forums
Old 11-04-2011, 07:28 AM   #1 (permalink)
Default Yakima Fairing or Windjammer experience?
I bought a set of Yakima RailGrab w/58" crossbars for my wife's 2008 Pilot, with every intention to remove them when we're not using them... Well they haven't been off the car in almost a year at this point. They do make for a significant increase in noise at highway speeds. Does anybody have any experience with either the Yakima Fairing or Windjammer? Does either do a good job at reducing the noise caused by the crossbar(s)? Do they have any impact to mileage? And if you've got a fairing what size did you install?
Any help would be greatly appreciated.
Thanks!
f2racer is offline   Reply With Quote
Old 11-22-2011, 02:20 PM   #2 (permalink)
I have the 66" load bars on my '11 and yes, there is definitely whistling at speed! I purchased the 44" Yakima fairing (part #8007048) and it helps a ton. Reduced whistling by 80% and no bad side effects that I have seen after 20K miles. I do have a Yakima SkyBox cargo tube, when that's installed you have to remove the fairing both for fitment & airflow reasons.
However, my bike, kayak, and ski racks all work very well with the fairing. I'll post a pic later if I remember to!
'11 Pilot EX-L 4x4 Taffeta White (Xenon Depot HID conversion, LED interior lights, Yakima Rack)
'98 Shadow Aero 1100 (pipes, bags, LEDs, etc.)
-- RIP --
'08 Element SC 5-Speed Rootbeer Metalic
'92 Accord EX 5-Speed
Opentoed is offline   Reply With Quote
Old 11-22-2011, 02:53 PM   #3 (permalink)
macphanatic's Avatar
I've got the narrower Yakima fairing on my 07. Definitely helped with the noise. Another thing to consider is to move the front bar as far back as possible when not using it. At the very least, it moves the noise source further back. I did have an issue with the outer corners of the fairing hitting the roof at high speed. I put some foam tape on the roof, but will be splitting some black vacuum hose to put on the lower edge of the fairing when I have a chance.
Old 05-14-2012, 09:01 PM   #4 (permalink)
Hi, mind telling me what size fairing you put on your 07? I've got an 05 and wondering if I should go with a 38" or 44". It would seem the between the factory rack is 42". I've got the yakima rail grabs and 58" load bars.
thanks
2005 EX-L Silver
Custom FX-R Bi-Xenon Headlights
Chrome Running Boards
Yakima RailGrab's + 58" bars
Yakima hully rollers (w/Necky Manitou II 80lb kayak)
Thule Evolution Roofbox
Weathertech Floor Liners (front, mid, trunk)
7 wire electronic brake setup w/Prodigy 2 controller
OEM hitch / Fogs
Pulling Rockwood Premier PUP
jezzy is offline   Reply With Quote
