2007 Honda Pilot - Change Fog Light Bulb + HID Installation - Honda Pilot - Honda Pilot Forums
Old 05-09-2011, 11:17 AM   #1 (permalink)
Default 2007 Honda Pilot - Change Fog Light Bulb + HID Installation
Hi,
I was wondering if anyone can kindly give me the details on how to change the fog light bulbs. I looked under the car and see that there's 2 clips and 1 nut bolt, but the instructions from bernadi parts, has no mention on the bolt. Can someone kindly tell me if I need to unscrew the bolt to change the Fog light bulb.
Also, has anyone install Fog lights HIDs? Where do you place the ballast? Also, did you have trouble running the postive red wire to the battery? Was it long enough? which route did you take.
Thank You,
Leo
leo38cheng is offline   Reply With Quote
Old 05-09-2011, 09:45 PM   #2 (permalink)
I changed my fog bulbs to Nokya 3000k bulbs a couple of days ago. Starting from the middle of the vehicle: there will be 1 clip (located more towards the engine), 1 10mm bolt, and then 1 more clip. After you remove those, you can pull out that liner piece to reach behind fog housing. There is another clip more towards the outside of the car near the wheel-well that you can remove to gain more access.
2007 Nimbus Gray EX-L w/Navi & 4WD
blueintegraboy is offline   Reply With Quote
