Roof Racks - Honda Pilot - Honda Pilot Forums
Old 04-22-2011, 12:59 PM   #1 (permalink)
Default Roof Racks
When I purchased my 2007 Pilot had a great deal on a 4x4. however it did not have a roof rack and running boards.
I found the running boards and the installation seems to be pretty simple, however I have hard time finding the roof rack and any instruction for installation which I assume a bit tedious.
Anyone has any experience with this issue ?
Thanks !
microswitch is offline   Reply With Quote
Old 04-22-2011, 01:04 PM   #2 (permalink)
Someone else did this recently. A search will find the thread.
Honda install instructions here-07 may have changed a couple of bits, but its pretty much the same as the 2003: http://www.hondapartsdeals.com/Honda...t/roofrack.pdf
Contact Tim on this forum "hondacuraplanet" for the best deals
Old 04-22-2011, 01:09 PM   #3 (permalink)
Wow ..!
Wonderful bud.. Thank you
Will contact Tim as you suggested
Old 04-22-2011, 02:25 PM   #4 (permalink)
I actually did install the Honda oem accesssory roof rack and cross bar assembly onto my 05 LX and it was not difficult. Only tricky part is cutting the metal gutter trim to correct length. Also, I broke a bunch of the plastic clips that hold the trim on. Be sure to buy some new ones as they are really designed for one time use only.
2005 LX 4wd
OEM accessory roof bars
OEM nerf bars
OEM rear splash guards
2006 OEM 4wd emblem
Garmin GPS
Aftermarket tinted windows
OEM accessory fog light kit
OEM accessory cargo cover
Silver painted grill
Acura stainless exhaust tips
KYB GR2 struts/shocks
Curt 13328 Hitch
Old 04-22-2011, 02:30 PM   #5 (permalink)
Oem Honda Accessory LX roof rack plus Surco Safari roof basket.
2005 LX 4wd
OEM nerf bars
2006 OEM 4wd emblem
Garmin GPS
Curt 13328 Hitch
