Viper remote start issue - Honda Pilot - Honda Pilot Forums
Old 03-12-2011, 08:34 PM   #1 (permalink)
Default Viper remote start issue
I recently installed a Viper 5701 in my 2004 Pilot EXl. The alarm system works fine, but the remote start has an issue. It will not crank the starter. I installed a bypass module, and hooked up the key sense and all of the accesory/ignition wires. All of the wiring was done according to the diagrams I found online. Anyone have any ideas? There are no error tones on the remote or flashing parking lamps after the remote start is engaged. Thanks in advance for the help.
-Mike
miketf is offline   Reply With Quote
Old 03-13-2011, 12:35 PM   #2 (permalink)
See if you can try to put the key in the ignition and then remote start it then. If it works then it is the key imobilizer interfering with it.
Jackalo626 is offline   Reply With Quote
Old 03-13-2011, 09:00 PM   #3 (permalink)
the key thing did'nt work. I tried disconnecting the imobilizer and using they to make sure it wasn't a problem with that. Still the same result.
