I have a Prodigy and wiring kit on the way from eTrailer. Anyone with a brake controller care to share installation tips? I have an 05 Pilot.
Where did you run the wiring? Where did you mount the controller? Thanks! |
Use good heavy wire.
Get your power strait from the battery. I put the controller under the "Not An Ashtray" I used small bolts with wing nuts as I though I would take it out when not towing to save space, but it really does not waste that much space, so it just stays in. It is easy to see, and easy to reach, and in a panic, the passenger could help. If it is on the drivers side you can not do that. Wiring enters from the firewall where the main harness goes through and exits from behind the glove compartment (through an existing grommet). Circuit breakers are in the dead space behind the center console and the firewall. I have also had problems with the trailer light converter. Seems I draw too much on the running/parking light line. I replaced the factory converter with a powered converter, but that circuit failed again, so I have a relay driving the running/parking light circuit.
Out behind the glove box and tied to the frame underneath.
Around the spare and meeting up with lighting harness right behind the hitch.
Evidently my search foo is weak. |
Just a quick thank you. I'm not finished wiring it up yet, but I'm pretty happy with how it's turning out. I'm running two-wire shielded 10awg (from the etrailer kit) inside along the driver's side, under the kickplates. I pulled the rear panel out enough to route the wire behind it along the existing wire harness, over the wheel well. At the rear, just behind the little storage tray, there are two existing grommeted holes right next to the existing trailer connector wire, nicely aligned for egress. I've installed new rubber grommets here and thus routed the wire out to the hitch. A bit of work, but it will be nice and clean.
Next up: In front I'll split the wire and connect one to the brake controller and let the other run through the firewall to the battery for the charge wire. Looks like the best place to get through is a large (3-4") grommet with a 1" bundle already through it, just behind the brake master cylinder. I think this is where Dustin's goes through. One question: For the charge wire, did anyone install an isolator/relay? the etrailer kit just has a 40a circuit breaker for this. |
