Hitch Question - Honda Pilot - Honda Pilot Forums
Old 07-07-2009, 05:29 PM   #1 (permalink)
Default Hitch Question
I am interested in adding a "towing package" to my 2003 Pilot (95k miles). I've looked at the threads here and on other sites. I'm pretty sure I want the whole package (coolers and what not) to tow my boat (about 2,000 lb's). I am just not satisfied with the $1,375 ($825 parts and $550 labor) my dealer wants to do the install.
I've looked at the installation instructions and they don't seem too difficult, but what I am wondering is how frequently others encounter unforeseen problems. I’ve noticed some discussion of bolts breaking. Is that a common occurrence or do most of the installs go off without a hitch?
Also, do most clean the threads, I don’t see that in the installation instructions, but know it was mentioned somewhere as a critical step.
Thanks for the input. Any advice on where to purchase parts would also be helpful if that is allowed here.
smalljaws is offline   Reply With Quote
Old 07-07-2009, 05:59 PM   #2 (permalink)
Check with Tim (HondAcuraWolrd.com) for a price.
You MUST, very carefully, clean the threads with a tap. (not a bolt!)
As for the rest, it is an easy job.
Old 07-07-2009, 08:14 PM   #3 (permalink)
Given that you are way outta warranty by now, consider using aftermarket coolers. Much cheaper than the pipe with fins approach Honda has.
There are a number of threads on coolers complete with installations.
Old 07-08-2009, 10:08 AM   #4 (permalink)
Ok, can you give be specs on the tap I need and an idea of where I might locate one?
Old 07-08-2009, 11:45 AM   #5 (permalink)
There are 3 sets of bolts for the factory hitch:
(1) 12mm x 1mm pitch (8 bolts altogether for the underside of the body)
(2) 10mm x 1mm pitch
(3) 8mm x ?? pitch
Any really good tool/machine shop.
