Cross Bars - Honda Pilot - Honda Pilot Forums
Old 03-30-2009, 07:39 PM   #1 (permalink)
Alpo714's Avatar
Send a message via AIM to Alpo714
Default Cross Bars
Hello Everyone,
I have a 2004 Honda Pilot EXL with the roof rack.
I would like to purchase and install the cross bars from Honda. But as a I was reading the instructions on how to install the cross bars, the directions indicate that: "The information in this installation instruction is intended for use by only killed technicians who have proper tools, equipment and training to correctly and safely add equipment to your vehicle. These procedures should not be attempted by "do-it-yourselfers."
See link below:
http://www.bernardiparts.com/Images/...y_AII30491.pdf
But as I was looking at the directions, its clearly, very easy to install. Is there anything technical or difficult about installing these cross bars that might require honda installation?
2004 Honda Pilot 4WD EX-L w/ Navigation
Alpo714 is offline   Reply With Quote
Old 03-30-2009, 08:12 PM   #2 (permalink)
RSQ Pilot's Avatar
Garage
Default Re: Cross Bars
Originally posted by Alpo714
Hello Everyone,
See link below:
From your quote above it probably would be difficult if your were a killed technician but as a live DIY the crossbar installation would be a piece of cake.
Old 03-30-2009, 08:54 PM   #3 (permalink)
Alpo714's Avatar
Default Re: Re: Cross Bars
Originally posted by RSQ Pilot
From your quote above it probably would be difficult if your were a killed technician but as a live DYI the crossbar installation would be a piece of cake.
Hahahha! Pardon my errors boys. Please replace "KILLED" with "SKILLED."
Old 03-30-2009, 09:06 PM   #4 (permalink)
jestmaty's Avatar
Feedback Score: 1 reviews
It seems that ALL of their instructions say that.... "Only a skilled technician..."
Don't sweat it, easy as pie to do yourself. I just did mine last month after buying the crossbars from another hp.org member.
Super, super easy if you can turn a screwdriver.
If you decide to diy, don't hesitate to pm, email, or ask on this thread if you get hung up. I, as well as any other hp.org member would gladly help you if you have any problems.
The LX model is a bit more sophisticated because you have to install the rails and stuff, but the EX models already have the longitudinal rails installed new at the factory.
2004 EXL-RES Sage Brush Pearl
2005 Bayliner 175XT Bowrider
Old 03-31-2009, 09:54 AM   #5 (permalink)
How much are you paying for the cross bars? I want some for my LX. I noticed the instructions you posted were for an EX. Does anyone know if the same bars will fit the LX? Anyone have any luck with good-looking aftermarket crossbars?
<b>2005 Silver EX</b>
bgmiller is offline   Reply With Quote
Old 04-03-2009, 10:47 AM   #6 (permalink)
Yes, the LX and EX are different, and I think the parts may have changed after 2007. I purchased my crossbars off eBay and installed them in about an hour.
Here are crossbars that are for sale on eBay now. http://cgi.ebay.com/ebaymotors/2003-...s#ht_500wt_788
2007 Pilot LX
2004 Suzuki V-Strom
Old 04-03-2009, 11:15 PM   #7 (permalink)
I just got a pair of the crossbars off Ebay and installed them tonight. However, I couldn't find the "mark" on the inside of the roof rails to position the crossbars. I know it's small but I swear I couldn't find it. Can someone measure the position of the mark from the end of the roof rails (either from the front or back) so I know exactly where to be looking? Thanks!
adinar is offline   Reply With Quote
Old 04-04-2009, 04:51 AM   #8 (permalink)
bigdadi's Avatar
This pic should tell the approx MARK location
BigD
Old 04-04-2009, 12:45 PM   #9 (permalink)
Thanks! Went back & looked again today and found the marks. Keep in mind that it's on the upper rail, and looks like a little dimple.
Old 04-17-2009, 12:39 PM   #10 (permalink)
Send a message via AIM to cworrall Send a message via Yahoo to cworrall
Default Crossbar holders
Where can I purchase the crossbar holder part seperatly? It's the part you screw the crossbar into. The one that slides into the rail. I stripped mine when I was installing them.
cworrall is offline   Reply With Quote
Old 07-31-2009, 08:24 AM   #11 (permalink)
Send a message via AIM to Puppetmaster
Default Re: Crossbar holders
I know this is months after the fact... but I did that too. 7 ft lbs of torque is not a lot at all, lol. I didn't find a replacement, but used a longer, slightly thicker bolt that went all the way through the bracket and was able retap itself securely, since all the included bolts to is tap into the bracket. I don't know how much I like the OEM cross bars because of that design, so I may just upgrade to a Thule rack later.
Puppetmaster is offline   Reply With Quote
Old 08-10-2009, 07:47 AM   #12 (permalink)
Default Rear crossbar question
Alpo or anyone else who has recently installed these---
The diagram shows a picture of the correction orientation of the front crossbar with the rubber strip closer to the front of the vehicle (narrow metal part in front & wider strip towards rear), but neglects to mention the orientation of the rear crossbar.
Did you install that one the same way, with the rubber strip closer to the front of the vehicle? I'd assume that's the correct way since the instructions don't show anything else...
StoneyPA is offline   Reply With Quote
Old 08-13-2009, 12:58 PM   #13 (permalink)
I don't know if the diagram in the install instructions is to scale, but it sort of looks like the rubber strip on the rear cross bar is closer to the rear of the car. That's how I installed mine and I hope it doesn't make a big difference, haha.
Old 08-17-2009, 11:41 AM   #14 (permalink)
It doesn't seem like it'd matter but still find it strange that the instructions only show the orientation of the front bar... if common sense came into play at all, they'd just note that BOTH are to be installed as shown OR make a simple note (or another diagram) that the back bar is different!!!
Those translations from foreign languages to English may have something to do with the missing info as well...
