Backup camera installation question - Honda Pilot - Honda Pilot Forums
Old 02-22-2009, 08:25 PM   #1 (permalink)
Default Backup camera installation question
I recently purchased a backup camera from an '07 Pilot from a salvage yard. It includes the camera, rubber bushing, and wiring that leads to a male and female white connector where the wires were cut about 3 inches after the connector. It also includes the larger rubber bushing and the correct color matched camera garnish.
I know that there is a kit for camera attachment kit from Honda, P/N 08B21-S9V-100, but it costs around $200. I do not really need all of these parts. Is it possible to order just two of the brackets I need to complete the installation? I need only the rear camera bracket and the rear camera subbracket. I could not locate individual part numbers for these. I would also require some riv nuts, scews and allen bolts. I should be able to get these at a local hardware store.
The template that comes with this kit would make things easier, but I probably can figure out where to mount it.
Any suggestions would be greatly appreciated.
jimmygtp13 is offline   Reply With Quote
Old 02-23-2009, 07:04 PM   #2 (permalink)
? Any ideas ?
Old 02-24-2009, 08:55 AM   #3 (permalink)
ED27's Avatar
Couldn't find a part no for the bracket either. Sometimes in these situations it might be worth it to ask you local dealer to see if they can source one. Otherwise I would try to make my own out of sheetmetal.
2004 EX-L NBP
Old 02-24-2009, 05:48 PM   #4 (permalink)
I'll just make the brackets. Thanks ED27!
