I've never towed/hauled anything before so I don't know much about it.
Next month I am taking 6 people + luggages to the airport (about 2hr of driving). So I am thinking why don't I get a cargo carrier (something like this one for the future use. My question is do I need to get a trailer hitch to install the carrier (I think I do but I just want to make sure). If I do need, where can I get after market one without losing a hand or leg? Can I get the one sold at U-haul? I've heard that people complain their installation. Can I buy it online and install myself? Can I only do the hardware installation with no wire because I only want to use with the cargo carrier only? I am not planning to tow a boat or anything like that. My PL is 08 with full size spair tire.
2008 Pilot SE 2WD Silver OEM Running Board, OEM Cargo Tray, OEM Moon Roof Visor, Full Size Spare Tire, Husky Liner, After market AT cooler |
Yes, it requires a hitch. Search the forums as hitch installation has been discussed several times. If you are mechanically inclined, it is an easy installation.
for the one you listed you would need a hitch but there are rooftop carrier options available as well.
-Mike.
2006 EX-L Nav, Billet Silver, Honda Hitch, ATF Cooler, PS Cooler, Honda Towing Harness, Honda Rear Mud Flaps, Catch-All 5 Piece Set, Rear Sub-Frame Kit, Honda Cross Bars, Spare Cup Holder, Factory Service Manuals, ScanGauge II, Softride Pull Pin Bike Rack, Poorman mp3 input, G-Net Navi Video adapter, AirLift 1000 kit. |
Ordered the Curt hitch ($152.95) + cargo carrier ($99) + wiring harness (24.95) yesterday at etrailer for total of $277.85. Today found out there was a coupon code 5% off. Emailed CSR, 5 min later got email said I would get credit back. Very good customer service
Got it yesterday and will install this weekend. Have a question though.
How do I know how much torque apply when tighten the bols using the torque wrench? Let's say 70ft-lbs. Does impact wrench let you know how much torque you use? I just bought one few days ago for tires rotating but haven't opened the box yet. I don't want under or over tighten the bolts.
As a side note, this is what commonly causes heartaches at the roadside. Some tire rotation tech uses 150 PSI in his impact wrench to re install your tires and you get stuck on the roadside with a dumb old lug wrench that can't break the lug nuts free when you need to.
