06 Bug Guard - Page 5 - Honda Pilot - Honda Pilot Forums
Old 10-08-2006, 11:34 PM   #61 (permalink)
blu_twstd_steel's Avatar
bluesdog64 - thanks for the feedback. I ordered the AVS model a few minutes ago.
Greg
also in NJ with a 2 week old 2006 steel blue metallic Pilot.
blu_twstd_steel is offline   Reply With Quote
Old 01-06-2007, 09:43 PM   #62 (permalink)
Any updates on your stone/bug guards? I've read that some people's experience with them aren't too positive as they still see some chips near where the guards should be protecting.
Anyways... I'm trying to decide whether to grab the AVS or the WTs for my Gray pilot. Anyone have a gray with one of those btw? TIA
07 EX-L 4WD ~ <a href="http://www.hondapilot.org/forums/showthread.php?s=&threadid=17105">Nimbus Gray</a>
OEM: Running Boards, Cargo Cover, Crossbars, and Rear Splash Guards
<a href="http://www.realtruck.com/productline/1481/1/1/weathertech_floorliner_floor_mats.html">WeatherTec h FloorLiners and CargoLiner</a>
wwong's pads + foglight protector
piku is offline   Reply With Quote
Old 01-09-2007, 07:01 PM   #63 (permalink)
The bug shield mounted easily. I did not use the bump ons (they are not needed). I did have to raise the catch that locks the hood down. I believe it was only 3 bolts you had to loosen in order to adjust it. Otherwise, you had to slam the hood pretty hard to get it to latch.
Old 07-26-2007, 12:57 PM   #64 (permalink)
Default AVS
My AVS bugflector just arrived last night, I will install it tonight after work!
2007 Nimbus Gray EX-L Navi. 4WD
OEM running board
OEM rear splash guard
AVS bug deflector
Custom tinted taillights
Philips HID 4300k from Lava Lighting
kevinaldo is offline   Reply With Quote
Old 08-01-2007, 01:04 PM   #65 (permalink)
Are there 2 different heights of the AVS model? I dont care for the really big OEM Honda bug guard.
2007 Honda Pilot EXL
2006 Toyota Avalon Touring
1996 Honda VFR750
2006 Suzuki DRZ 400S
scott996 is offline   Reply With Quote
Old 08-01-2007, 01:07 PM   #66 (permalink)
Default Re: AVS
I installed mine...it's easy installation except removing the existing self-tapping screw...will show pictures later
OEM running board
AVS bug deflector
Old 08-06-2007, 02:28 PM   #67 (permalink)
Is the AVS the full height one-or the regular bug guard II? The item numbers are the same so its a bit confusing
http://www.car-stuff.com/performance...=168&category=
1996 Honda VFR750
Old 08-27-2010, 08:30 AM   #68 (permalink)
stewie1958's Avatar
thank you, I have had a couple that didnt fit, and was unsure about the weathertech, this is the one I'll get
stewie1958 is offline   Reply With Quote
Old 09-23-2010, 10:38 PM   #69 (permalink)
2 weeks ago I purchased the weathertech bugdeflector installed in ten minutes no issues with closing the hood. It does have the weathertech log which I will be removing shortly. I went with weathertech as they are 7 miles from my home. The gentleman there told me that if I damage it ie. carwash,rock they would replace it at a reduced rate.
2007 Pilot EX-L 4WD/Navi, WeatherTech Bug Guard, Neo Ipod adapter, WeatherTech Liners
2005 CR-V EX AWD Fogs,WeatherTech Liners
rbm11761 is offline   Reply With Quote
Old 10-10-2010, 10:42 PM   #70 (permalink)
hey guys!
I love this forum, I just got a 07 Pilot CPO and it comes with the OEM Bug Guard, I was wondering if I should keep it or get a AVS or weathertech.
thanks!
Leo
leo38cheng is offline   Reply With Quote
Old 10-11-2010, 12:24 AM   #71 (permalink)
cofetym's Avatar
Send me the cash and I'll think about it for you.
____________
2005 EX-L 4wd
Old 12-12-2011, 02:29 PM   #72 (permalink)
I might go the Weather Tech. I havent heard of any required adjustments.
Raymond_12000 is offline   Reply With Quote
