I read through several threads over the weeks and they all talked about how easy it was to install running boards so I opted to do it myself. I saved more than $150 in labor and another $100 buying them from http://www.fairhondapartsforyou.com based on other Piloteer's recommendations. They are genuine Honda parts - see the following pic.
One essential DIY which helped me visualize the installation with clarity was from Oahu_Dave who installed side steps: http://hondapilot.org/forums/showthr...ght=side+steps Tools needed: 13mm socket 13mm combination wrench Extension (I purchase a 6") Torque wrench (not required, but I chose not to chance stripping threads) Another thread helped me find an inexpensive torque wrench: Torque Wrench Recommendation Since I'm not much of a gear head, this one worked for me just fine. Hunting for OEM parts, I found them via Wwong's thread http://hondapilot.org/forums/showthr...light=websites
2005 Steel Blue EXL Cargo cover Weathertech rock/bug deflector Running boards Mud guards |
The parts were impeccably packed. Each bracket part was individually wrapped in plastic and neatly stored.
Here's a close-up of he board. Please excuse the cardboard dust.
Here are the bracket parts neatly stored in two boxes
Instructions for FRONT brackets
Next the CENTER and REAR brackets
Now attached the bracket which supports the running board
Next find the clips under the truck (2 not pictured here)
Remove them. Punch the center of them in with a thin object (I'm using my smallest philips screw driver here) and you should be able to pull them out with your fingernail
Here's a shot of the center pillar under the truck where the other side of the bracket is attached to. Notice - no clips to remove
#15 (permalink) |
Here's a front bracket installed - Remember to keep all bolts loose
