A Fully Padded Glove Box - Honda Pilot - Honda Pilot Forums
Old 12-31-2004, 08:20 PM   #1 (permalink)
wwong's Avatar
Default A Fully Padded Glove Box
At the request of a few members, I finally got around to making a fully padded glove box. Here's the five piece set I made. Material is the same material I use for the console pads, 1/16" thick neoprene foam with a textured surface on one side and 3M adhesive on the other side. Fits all '03 to '08 Pilots.
Custom Non Slip Foam Pads for the Honda Pilot, Click here to visit my website
2003 Honda Pilot EXL-NAV, Starlight Silver, #86733 "Featured Pilot March 2004"
EXTERIOR-Perfect Fit Hood Guard, Lower Trim, Lower Trim Garnish, Bumper Garnish, Fog Lights with Eurodezigns H3 bulbs, Wheel Locks, Fender Flares, Crossbars, Door Mirror Covers, Vent Visors, Running Boards, Rear Splash Guards, Trailer Hitch, Pilot #PM555 Stainless Steel Exhaust Tips, Euro Dezigns H4 replacing Sylvania Silverstars, Tire Minders, EX emblem, Third Brake Light Decal, Michelin CT, Chrome OEM Wheels, Muth Signal Mirrors, Sylvania #885 Back Up Lights
INTERIOR-Wooden Shift Lever, Wood Grain Interior Trim, All Weather Mats, Cargo Cover, Cargo Organizer, Cargo Tray, Cargo Liner, Trunk Organizer, Broadway Optics Mirror, Raybrig R130
ELECTRONICS-Networkcar, Power Inverter, Nav DVD upgrade V.2.11C, Rear View Camera
CUSTOM ACCESSORIES- Door Edge Guard, Foam Pads for Center Console and 2nd Row Activity Tray, Foam Pads for Doors and 3rd Row Bins and Cupholders, Dead Pedal Cover, Cargo Storage Pad, Padded Glove Box, Sunglass Holder Pad, Pillar Protection Tape, Fog Light Covers, Door Reflectors, Cargo Liner Velcro Replacement Kit, Chrome h-p License Plate Frame, VTM-4 emblem, Chrome Accent for the OEM Lower Trim, Chrome Accent for the OEM Running Boards, Chrome Grille Accent, Navi Screen Protector, Non-Slip Pad for the OEM Cargo Tray, hp.org sticker and tee
wwong is offline   Reply With Quote
Old 12-31-2004, 08:22 PM   #2 (permalink)
wwong's Avatar
You have to remove the glove box from the Pilot to start. There are a couple of screws at the lower corner of the glove box. Use a 9mm socket or philips screw driver to remove the screws. You will need to remove the quarter panel to access the right screw.
Old 12-31-2004, 08:23 PM   #3 (permalink)
wwong's Avatar
Remove the rubber stop from the glove box. There's two of them. One on each side of the glove box. They're just clipped on.
Old 12-31-2004, 08:24 PM   #4 (permalink)
wwong's Avatar
Put on the back, left and right pad. If the pad is not installed correctly, just left and reapply.
Old 12-31-2004, 08:26 PM   #5 (permalink)
wwong's Avatar
Use a razor blade or utility knife and cut out the pad covering the hole for the rubber stop.
Old 12-31-2004, 08:27 PM   #6 (permalink)
wwong's Avatar
Pop the rubber stop back on.
Old 12-31-2004, 08:28 PM   #7 (permalink)
wwong's Avatar
Then put the top and bottom pad on. The bottom pad is the toughest to install because of the contours.
Old 12-31-2004, 08:54 PM   #8 (permalink)
Le Moderator Ranger
kemosabe's Avatar
How much $$$ for this set???
Old 01-01-2005, 07:11 PM   #9 (permalink)
wwong's Avatar
Here's a picture with the glove box back on my Pilot.
Old 01-01-2005, 07:15 PM   #10 (permalink)
wwong's Avatar
With the owner's manual, registration, and flashlight in the glove box, nothing slides around. Cost is $20 + $5 S/H. If you are interested, send me a PM for payment details.
Old 01-14-2005, 08:19 PM   #11 (permalink)
ryanb's Avatar
Thanks Wilson I got your package this past weekend and installed the glove box kit, fog light covers and edge guard tape. The installation for everything was very easy including removing the right side glove box bolt which I was able to do with a 1/4” ratchet and a 6” extension.
Just one curiosity question; why is the bottom piece of the glove box kit not the same width across its length?
Great products, thanks again.
ryanb is offline   Reply With Quote
Old 01-14-2005, 09:50 PM   #12 (permalink)
wwong's Avatar
Not sure what you mean. Post a picture here or email me. The bottom pad is the most difficult to install because of all the contours.
Old 01-14-2005, 10:29 PM   #13 (permalink)
jay
jay's Avatar
Why is the piece circled in blue narrower at one end than the other is what was meant.
Old 01-14-2005, 10:33 PM   #14 (permalink)
wwong's Avatar
Oh, I see what you mean now. The pad is slightly tapered because the back of the glove box is slightly tapered.
Old 01-15-2005, 01:07 PM   #15 (permalink)
ryanb's Avatar
Thanks Wilson, I guess I’ll have to go back and refit that piece since when I did a dry fit I couldn’t find a position that would accommodate its taper. It appeared to me that the wide end of the bottom piece was too wide and the tapered end not wide enough for either end of the box; hence my curiosity.
