Cleaning the inside of wheels - Honda Pilot - Honda Pilot Forums
Old 04-28-2007, 05:03 PM   #1 (permalink)
Default Cleaning the inside of wheels
I need a good way to keep the "backsides"(insides) of my wheels clean. Any suggestions?
smithjason is offline   Reply With Quote
Old 04-28-2007, 05:55 PM   #2 (permalink)
rlapid's Avatar
i use a sponge and just try to squeeze my fingers through all the little spaces between the spokes. i can't get to the deeper parts, but nobody sees that anyway. maybe you could remove the entire wheel...
Old 04-28-2007, 06:09 PM   #3 (permalink)
Thanks. I'm thinking about soething I can do at tire rotation time when the wheeels are off. A polish of some kind to help keep oxidation down.
Old 04-29-2007, 01:55 PM   #4 (permalink)
Ran across some good advice today:
Clean the inside of the wheel with a scuff pad (Scotchbrite pad) and wax the inside of the wheel. It will keep it clean and prevent ocidation.
Looks great!
Old 05-03-2007, 11:04 AM   #5 (permalink)
Looks great!
i wouldn't recommend scotchbrite pads as you run the risk of scratching the clear coat on the wheels. Clear coat failure can lead to oxidation of the aluminum wheels.
Detailing clay works wonders in removing baked brake dust. Once it is cleaned you can apply polish and sealant.
kuota is offline   Reply With Quote
Old 05-03-2007, 10:27 PM   #6 (permalink)
Thanks for the tip. I verified with the Honda dealer that the insides of the wheels are not sealed, this the fast pitting and oxidation (this Pilot is only 3 months old).
I'll treat them with care.
Old 05-07-2007, 11:08 PM   #7 (permalink)
Nathan @ NBO's Avatar
Why not just clean them and apply some clear coat, possibly the engine enamel type (high heat)
<a href="http://www.neverburnout.com">NBO HID Kits and HID Bulbs</a><br>
Every NBO HID Kit is GUARANTEED FOR LIFE
Nathan @ NBO is offline   Reply With Quote
